Same 3 Point Hitch for BX22---->BX25?
   / Same 3 Point Hitch for BX22---->BX25? #1
Tractor Factor
Gold Member
Outer New York
Kubota BX25, BX1860
Ok, so I've got to buy a 3 point hitch for the BX25, because, as you all know, it is not included with the tractor any more. I'd like to save $100 and get an aftermarket one, seeing how the only thing I plan to use it for is a carryall now and then. Even if just on principle, I think I should have one.
Any of you BX owners know whether either of these might fit or if the BX22, 23, 24 and 25 all take the same hitch?
3pt Hitch Kit for Yanmar & Kubota Compact Tractors - eBay (item 180308473317 end time Nov-27-08 10:22:28 PST)
3 POINT HITCH KIT FOR KUBOTA ISEKI AND OTHER TRACTOR - eBay (item 290277396582 end time Nov-30-08 01:00:00 PST)
   / Same 3 Point Hitch for BX22---->BX25? #2
first link you provided, the arms looks somewhat longer then the BX24. the second link, I like the telescoping pin tightener. also the second link looks like the arms may need to be reversed so the connections are on the inside. you also will need to purchase the bushing to fit on the round bar on the outside. Either one you get, you might, from judging from the pictures, have some modifications to do.:(
   / Same 3 Point Hitch for BX22---->BX25? #4
Your second link looks like what my B7610 setup has. That long rod that acts as the pivot point isn't included in the first set. If it is not already on your tractor, it could be an expensive 'extra' part.
Ha, thanks guys, it's kind of what I suspected...Kubota's got me by the short ones.:D Guess I'd rather it fit right the first time than screw around trying to make it work.
   / Same 3 Point Hitch for BX22---->BX25? #7
I use my 3PH all the time. The BH goes on and off easier than the 3PH. When I grow up, I want to have another tractor with the 3PH on all the time and my BX as a TLB.
   / Same 3 Point Hitch for BX22---->BX25? #8
I'd disagree. Probably 3/4 of BX -TLB owners never use the 3pt. If you need it, its priced affordably.
My BX 23 was $15500 and included the 3 point .
$15300 with out the 3 point and $400 for the 3 point later is not afordable pricing in my math.
   / Same 3 Point Hitch for BX22---->BX25? #9
not trying to start an arguement - but 3/4 of bx's is alot of owners. just judging by the TBN'ers here, 90% or higher use the 3PT on the bx's. in the real world , number might be higher. Dont you think during the course of ownership , 98% of bx owners do get around using and trying out the 3 pt hitch at least once ? where do you get the 3/4 percentage from ? from just selling them the BX's and never hear from them ? I am sure majority of BX onwers goes to other stores like TSC or fleet , or even get used ones for 3 pt implements so dealers never really hear about them using the 3 pt hitch.;) hope I didnt setoff any wars here.. :D:)
   / Same 3 Point Hitch for BX22---->BX25? #10
Here I am using 2 of my three 3 point hitches at the same time on the same projcect / task .
Image of tilling - Photobucket - Video and Image Hosting
Image of drag up - Photobucket - Video and Image Hosting
When I grow up
Wonder if that will ever happen?:D
If I didn't have a 3 point(s)
I couldn't use the tiller and drag pictured.
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2017 FREIGHTLINER...
2012 FREIGHTLINER CASCADIA (A50854)
2012 FREIGHTLINER...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
2015 FORD F-250XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-250XL...
2021 Isuzu NRR (A50323)
2021 Isuzu NRR...
