DIY Home built compact tractor
   / DIY Home built compact tractor
Ok, where did I leave off?
I rebuilt the injectors and still couldent get it to start... Well I did get it to start... by putting 24 volts to the starter ( cost me a starter and glow plugs)! But it wouldent start on 12 volts. I jurry rigged a way to test the compression and found 2 cylinders low.
So I rebuilt the engine. It had 2 broken second rings and a scuffed piston.
I got it all back together and took it for a test drive. It dosent have a clutch or any brakes yet, so I started in gear for the test.
In 1st gear, at an idle it moves at about a medum walk. But that is with the taller rear ring and pinon still in. With the lower R&P it should move at half that speed, so I think it will work fine.
Heres a pic of myself and son, not moving.
Please forgive all the jurry rigging, but for testing purposes it works!:D
( Like that 8D battery box seat?!:p)
Heres a pic at idle speed.
   / DIY Home built compact tractor #252
Wow, Glad to see it come so far. You're going to have one nice machine.
   / DIY Home built compact tractor #253
Glad to see you got it running!! :) oh BTW, I love that shop of yours too. How big is it??
Thanks for the comments Iplay and Will.
The garage is 24x40' with a leg out the rear left thats 20x15'. It has 16' ceilings with a storage loft on one side.
Tim
   / DIY Home built compact tractor #255
Tim
Beautiful. How wide is the door? How tall?
   / DIY Home built compact tractor #257
welcome back- we were wondering where you went with this project. Now we know why and it looks good. Keep it coming!!;)
   / DIY Home built compact tractor #259
I assume that first ride got your adrenaline going, giving you an energy (and motivation) boost to continue the build ??
Most of my projects come to an allmost complete halt, then when the first successes are celebrated, i get motivated to finish it off working evening after evening... :)
Well I'm not quite that gung ho in my old age :rolleyes:, but yes I do tend to operate on the surge principle ;).
Tim
2017 Chevrolet Silverado 3500HD Ambulance (A52377)
2017 Chevrolet...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
2021 CASE IH 345 LOT NUMBER 12 (A53084)
2021 CASE IH 345...
13in Excavator Tooth Bucket (A52377)
13in Excavator...
2022 CATERPILLAR 242D3 SKID STEER (A51406)
2022 CATERPILLAR...
2014 Toro Workman HD 07369 Utility Cart (A51691)
2014 Toro Workman...
