How much does it cost to build a pole barn??
   / How much does it cost to build a pole barn?? #1
Pushing_Tin
Gold Member
Eugene, Oregon
JD 3320
We are building a new house and we need an outbuilding to store the tractor, firewood, lawn mower etc. I'm looking at having a mini barn built, but they want about $2k for a 10x20 size. Can anybody tell me what it costs roughly to have a pole barn built? Ideally it would be 300-400 sq ft.
Thanks! :D
   / How much does it cost to build a pole barn?? #2
We got a 28x40x14' barn built last year with parts, labor, concrete floor, and site prep for about $20k. That does not include any electrical work or door openers, though it included 3 overhead doors of 10x10 each. This was by far the lowest quote I got and the local building inspector told me I was lucky the company I used did a decent job because they often don't, per him.
Same company and several others advertise barn packages in the local Saturday paper for about 1/3 that price (for similar size 30x40x10) but such packages are apparently just materials for a super-simple barn.
I have not priced a smaller size barn like the 10x20 you're talking, but $2k sounds low to me. If it's a reputable builder - great! Might be worth asking the local building inspector if he's heard of them before you sign a contract.
   / How much does it cost to build a pole barn?? #3
I had an 18'x26' steel carport installed for about $4k. Then I included sides; doors; windows; etc...on a gravel pad. Local quotes for a similar pole barn were in the $12k range to start.
Thanks for the replies guys, I need something very very basic. Just enough to keep the wood and tractor dry. The only good thing about keeping it under 200 sq ft is I don't have to get a building permit, which is ridiculous here. Any other replies are welcome!
So what was the total cost when you did it this way?
   / How much does it cost to build a pole barn?? #6
I built a 12 x 18 shed for my dogs last fall. Had about $2400 in it, building it myself. This included concrete for the shed floor, plus an additional 13 x 8 concrete slab to add to the existing dog runs. I used 2 x 4 to frame the walls, used OSB for the walls and vinyl sided the exterior with two small windows. However, I did not have the cost of an overhead door because i was able to get by with a 36" man door. I also got a deal on trusses (they were 6/12 pitch but only half a truss because I think they were for a porch roof. I was able to put two together to make a normal truss and there were just enough trusses for my shed.
Hope this helps.
   / How much does it cost to build a pole barn?? #7
can you put a lean to on the side of the garage?
I did one of those for a buddy several years back for about $600.
otherwise, $6-10k is the price range around here for a 30x40 w/10' sidewalls - and you have to have the dirtwork or concrete done before they show.
Lowe's has a 10x14 steel garden shed under $500 right now. the wood sheds are close to that $2k you mentioned.
check your local lumberyards for package deals, too.
   / How much does it cost to build a pole barn?? #8
Thanks! :D
If you really want a rock-bottom price, last December I picked up on a 10' x 20' car garage (the kind made out of tarps on a steel pole frame) for $100 at Joe's in Medford. They are usually closer to $200.
If the height is enough for you this will get your stuff out of the rain for a year or so. This gives you time to decide what you really want in the way of a pole barn, and also lets you live in the house for a while and decide where you really want the barn.
That's some sound advice Dave, thanks! BTW I was born in Grants Pass. I also work the airplanes in and out of your airport. :)
   / How much does it cost to build a pole barn?? #10
I second Curly Dave's suggestion. I got 2 of these 10x20's at Costco.
One houses my tractor up on Denman island when it is there. The other one is holding all my 'treasures' while I rebuild my 20x32' garage (about 10k in materials so far...).
Check around there are some really light weight canopies that fly away at the first breeze. Mine have 2" steel tubes for the frame and full set of walls.
   / How much does it cost to build a pole barn?? #11
you can also get an 18x20 version for about $300.
   / How much does it cost to build a pole barn?? #12
I'm building....hope to build soon, a freestanding 30x20 foot 3 bay shed for tractor and implements. One bay may be set up as a horse stall. It will be open sided, have a metal roof and dirt floors. It looks like its going to cost me about $1500 (building it myself).
I may close it in and put a cement floor in the tractor bay in the future.
   / How much does it cost to build a pole barn?? #13
I ended up having Betterbuiltbarns.com build me several small barns that I use for chicken coop (8 X10 $1,100) , retreat shed (8" sides 10 X 12 = $2,000) and tool barn 16 X 20 with 8" sides I think was between $3-4,000. Love them! added some custom windows, sheetrocked the retreat shack and a few other additions - all told spent between 8-10,000 for all three buildings. They build on site. you prep ground
I was planning to house my riding mower in the big barn but jammed it with other things.
Still need storage for Kubota and mower so googled the pole barn and found this great forum. Based on the numbers everyone posted :eek:I may go back to the folks at BetterBuilt Barn - they used to be dairy ranchers now build these - do a good job - just need to make sure you get calk and paint on asap to preserve the thing.
   / How much does it cost to build a pole barn?? #14
I built a 12 x 16 for around $1000, but been a few years. That is material only, I supplied the labor while waiting for my building permit to get approved.
My 30x48 pole barn cost me around $11K in materials and another $2500 for 3 good insulated overhead doors. again I supplied the labor.
   / How much does it cost to build a pole barn?? #15
Any chance we could see a few photos of your 30x48?
Wedge
   / How much does it cost to build a pole barn?? #16
Wedge
Here's one when I was building the drive to it. I put 10x10 door in back end middle, and you see the 10x10 and 10x8 door on this end. If I had a do over, I would put one door each end, probably 12or14 x 10. Another do over would be to put bubble foil on before the metal.
I have not concreted the floor yet, I need to start that soon. Maybe I'll post and ask for recommendations. I'm thinking of putting insulation under the slab and putting PEX loop in the slab just in case I might want to someday heat it....
I have more pics from construction if you want to see.
   / How much does it cost to build a pole barn?? #17
Heres some more before & during.
I designed it myself and made my own CAD drawings, but the company I bought the material from provided detailed construction drawings also.
   / How much does it cost to build a pole barn?? #18
buckeyefarmer - I am interested in the pole you have mounted on your tractor. I see some sort of a cable and pulley mounted on it to lift your trusses in place. Can you tell us more about your FEL boom lift? how did it mount to your tractor, how did well it work, etc. ;)
   / How much does it cost to build a pole barn?? #19
10x20 is a pretty small barn but 2K isn't a bad price. Will this size be tall enough to drive your tractor into.
I'm in the planning stages of building a 32x40x14 pole barn. I don't know about your part of the country but on the east coast in PA there is a dealer who sells pole barn kits for the DIY'er. I'm planning on building mine within 6-8 month's so I've contacted a local pole barn builder in my town to quote me a kit price for materials only (one that I would build myself) and a completed shell with floor that he would build and I could finish the inside. Check your area for pole barn builders and shop around.
   / How much does it cost to build a pole barn?? #20
Thanks! :D
I am going to have a 24X32X12, 1 ft. overhang,overhead door,36 inch service door,40 year warrenty metal sides and roof for $7000 erected.coobie
2020 Ram Promaster City 1500 Cargo Van (A59230)
2020 Ram Promaster...
404 (A52706)
404 (A52706)
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2017 Ford Escape SUV (A59231)
2017 Ford Escape...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A61306)
2021 Takeuchi...
2018 Chevrolet Camaro 1LT Coupe (A59231)
2018 Chevrolet...
