Fence Questions
   / Fence Questions #41
Here in fla. we do use telephone poles, but ya better brace well if you dont you will just pull your corner over a few inches. A fence is only as good as its corners and braces.
   / Fence Questions #42
What size poles, and how deep? I have been using 16"-18" poles 48" deep, only back fill with dirt. Have had no movement that I can tell. Fences are all straight and tight. Just goes to show ya how much circumstances dictate what needs to be done.
   / Fence Questions #43
definitely post a thread of your project. i have some fencing to do myself.
   / Fence Questions
I will definitely post a thread once I start on it. I am excited to get going with it.
As to the poster who used old telephone poles: I have done that in the past. I bought some for $10 each, cut them up, sunk them 48" deep, and braces with 2.5" pipe. Tough posts, and last quite a while.
I will be using Red Brand for sure, not the Keystone. I have looked into high tensile, but I have made the decision to use the field fence.
   / Fence Questions #45
I agree with you that a field fence is a good idea. Did you know that there is also a high tensile field fence. It also allows you to reduce the number of fence post you need to one every 16 to 20 feet. Solidlock is one brand that I have used and liked. The cows could lean against it and it would spring back when they moved on.
Bekaert Fence Products
Rick
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
THREE POINT ATTACHMENT (A58214)
THREE POINT...
DOOSAN G25KW GENERATOR (A58214)
DOOSAN G25KW...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
Friesen 240 Seed Tender (A59814)
Friesen 240 Seed...
TANK MANIFOLD (A58214)
