DIY Home built compact tractor
   / DIY Home built compact tractor #262
Wow, that thing looks great. My hat is off to you sir. If I undertook a project that big, I'd probably wind up single again.
   / DIY Home built compact tractor #263
I didn't take the time to read through all of the info here, but I did want to share in case you didn't realize, but on your tractor if you are n 4wd and since you have 2 different size tires, unless you changed gear ratio's in your front or rear diff to occomdate the different axle speeds you are going to bind up your driveline and start to break things.
   / DIY Home built compact tractor #264
In the previous page the author noted testing with the taller rear gears so I suspect he plans to replace the rear. I think Samurai's came with 3:73s or 3.90s and the aftermarket has a 4.56? Nice thing about the samura removable third member is ease of repair. An aftermarket 4:1 gears for the transfercase would make it a stump puller. This tractor if the drivetrain is stock would go 90KMPH so might want to lock out the high range. :)
   / DIY Home built compact tractor #265
Theres is also 5.12's from the front of manual sidekicks. Although discontinued I think there were 5.83's as well. Quite weak though. 6:1 t-case gears are also available.
I'm using 5.38's in the rear.
   / DIY Home built compact tractor #267
Can't recall ever hearing a problem with the 5.38's.
A little up date.
I have installed the new, lower ring and pinion gears in the rear axle.
The test drive dident yeald the slow down I had hoped for, but I think it will be ok. It moves at what I call a slow walk, at engine idle.
Sorry no pics, the wife and son have the camera with them, in Arazona on vacation.:(
   / DIY Home built compact tractor #269
:( a face like this when the wife and kids are gone on valentine's day and you get unlimited time in the garage!:confused::D
i dropped big jack on mine tonight....most expensive steak in the county and we've got a whole freezer full!!!........maybe it'll pay off;)
A little up date.
Ha, actually the frown was cuz the camera is gone and I cant document my progress:D
Shhh, dont say anything!
FUEL TANK (A50854)
FUEL TANK (A50854)
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
2011 FORD F-250 SUPER DUTY (A50854)
2011 FORD F-250...
1996 PETERBILT 357 35 TON WRECKER (A50505)
1996 PETERBILT 357...
2011 FORD F-250 (INOPERABLE) (A50854)
2011 FORD F-250...
