BX7326 Rear Aux. Kit (install)
   / BX7326 Rear Aux. Kit (install) #21
I was wondering about whether these setups would provide enough flow to run a hydraulic implement or not as well? The lines look a bit small to really do the job from a flow perspective for anything that has a hydraulic motor.
Also, an interesting tidbit, after looking at your installation pics, I took a look at my B3030 Sunday night. My rear wheels have 2 studs each, and the rest of them are bolts. Should make re-installing the rear wheels far easier!
Steve
   / BX7326 Rear Aux. Kit (install) #22
Hi mgic
I also posted about ifitting on BX1830 but the guys get tunnel vision and look around an answer
Seeing my Bx has cruise control where he located his lever I would think it will not work on my particular model
Your application may be different
Still waiting for an answer
Regards
DGS
   / BX7326 Rear Aux. Kit (install) #23
mentat30 said:
I wouldn't think you could run a hydraulic motor with that type of valve, a hydraulic motor would need a valve made for hydraulic motors. Not sure about the line size.
   / BX7326 Rear Aux. Kit (install) #24
DGS said:
Hi mgic
Regards
DGS
DGS,
I have a BX1500, which did not have cruise control as an option (something tat I am sure could be added). The interesting thing about that is where I have the black slot on the fender cover is a symbol of s cylinder, which leads me to believe that remotes maybe available for my unit???
DGS said:
Hi mgic
Regards
DGS
DGS
The valve kit part# for the 1830 is BX7322 and it mounts to the ROPS. Also you have to order a hose kit and the hose kits depend on what other options you aready have on your tractor. The hose kit part#s are BX7323, BX7324 and BX7325. You chose just one depending if you have a loader or not.
   / BX7326 Rear Aux. Kit (install) #26
Nice job actionaj! That is what all remote hydraulics should look like. I am a fabricator by nature, however I think I will opt for the factory setup if one is available for my BX2230. I would not mind losing the cruise control feature, because I never use that anyway. Cruise control seems dangerous on tractors. At least I don't like the way the cruise control disengages sometimes. I only mow 3 acres, so its not like I'm on the back 40.
Again, Great job and thanks for contributing.
   / BX7326 Rear Aux. Kit (install) #27
This weekend I installed the BX7326 Rear Aux. Kit on my 2350...
Does anyone know if Kubota makes a kit for a third function loader valve (for a grapple or 4 n 1 bucket) for the BX line?
Thanks- John
   / BX7326 Rear Aux. Kit (install) #28
Not that I am aware of, I believe that the Rear Aux is kit is the only one. You could run one off of that. Or Rig something up yourself.
   / BX7326 Rear Aux. Kit (install) #29
I don't think the rear kit will fit because I already have rear hydraulics for the backhoe.
   / BX7326 Rear Aux. Kit (install) #30
The BX7326 Kit doesn't fit the BX24. Valve location interferes with the subframe, and the pre-bent steel lines/QD mount doesn't fit the 24's ROPS. Don't know if the kit can be adapted...no one's tried/reported back yet. Every time I look at that empty hole in the right fender, I'm tempted to try...:cool:
2018 XCMG XE210CU CRAWLER EXCAVATOR (A52576)
2018 XCMG XE210CU...
378573 (A51573)
378573 (A51573)
2013 FREIGHTLINER CASCADIA (A52472)
2013 FREIGHTLINER...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A52472)
2013 XLR...
2020 Steiner 450 Slope Mower (A51573)
2020 Steiner 450...
2022 Wacker Neuson SM100 Mini Skid Steer (A52748)
2022 Wacker Neuson...
