Backhoe Backhoe first time!
   / Backhoe first time! #41
I think I see what you are talking about in the second pic. On mine, there are tabs welded on the bottom ends of the tank. These tabs bolt to metal frame plates that are bolted down to the lower hoe frame where it bolts to the sub frame rails. These are the 6 rear bolts you need to check regularly(kind of hidden behind the pump hoses). I usually wind up setting with my heels resting on the tank, so I don't see how your setup would be very comfortable. Here is apic of mine, and my grandson leaning in to look at a spider:)
Ron, Re: your post #27: I ordered a 45/64" drill bit I'll tap the return 1/2" NPT and instal a 1/2" street ell. I haven't looked at the return line origin is it at the valve body? If I can open that up I'll do that also. Richard
   / Backhoe first time! #43
Yesw, it is up on the valve body, on the right as viewed from the operators seat. If I recall the fittings are 18MM. You should be able to get an 18MM-NPT adapter at your local hydraulic shop, and you could replace the whole hose quite easilly with an oil rated 1/2" hose.
Got some other things to take care of, when I can get back to that I will. Pushes oil out the filler when it gets warm, can't put up with that. Richard
   / Backhoe first time! #45
Neither could I, that is why I relocated the breather...
Drilled the return, threaded to 1/2" NPT.
Can't post a picture. Richard
Hardpan, punched a hole in the filler tube below the tank top as you discribed. Richard
Hydraulic tank return. Tapped to 1/2" NPT. Shown with street ell and barbed fitting installed.
Original male to male fitting threaded to 3/8" NPT. Shown with 3/8" ell. Fitting ID was drilled out larger than brass fitting ID to be attached.
Ih 4300 Field Cultivator (A50514)
Ih 4300 Field...
2021 Caterpillar 304E2 Mini Excavator (A50322)
2021 Caterpillar...
New Swict 60" Skidloader Bucket (A50774)
New Swict 60"...
2015 F-550 Bucket Truck Gas Engine (A52128)
2015 F-550 Bucket...
2007 Terex RS350 Soil Stabilizer/ Reclaimer (A49346)
2007 Terex RS350...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
