Hydraulic cooler on my CK25
   / Hydraulic cooler on my CK25 #61
Mike,
Your picture shows the same corner on the oil cooler where the leak developed on my CK30. Perhaps it might behoove us to look into the aftermarket oil cooler arena and see if there is a less expensive replacement available.
Don
   / Hydraulic cooler on my CK25 #62
The stock cooler is a Modine oil cooler.
It's not a cheap cooler.
BTI
   / Hydraulic cooler on my CK25 #63
Oil cooler dimensions in attached pictures...
Don
   / Hydraulic cooler on my CK25 #65
For comparison, my cooler is considerably larger. The connections are rubber type hoses with hose clamps to secure them.
   / Hydraulic cooler on my CK25 #66
What do you call the connections to the cooler? Threads/size/etc?
Mike
I don't know the size of the bolt or threads. I'll do some thread sizing research at the hardware store on my next trip. The bolt is a custom bolt, it has an elongated shaft with a hole in the shaft for the oil to circulate through.
Don
   / Hydraulic cooler on my CK25 #67
MDM what tractor do you have, did you change the cooler from stock?
Mike
   / Hydraulic cooler on my CK25 #69
Tnx for threads.
Went to modine corp and asked them about kioti oil coolers, will report back if any response.
I wonder if anyone has this "wet" lower coil cooler syndrome and it just goes on forever and doesn't cause any more problems.
And also, more clarification on the subject of the hard lines vs. the flex lines. In at least one case above, flex lines did not prevent a NEW kioti oil filter from leaking.
Mike
   / Hydraulic cooler on my CK25 #70
From Modine just now:
Dear Michael,
Thank you for your inquiry. Kioti is not a Modine customer.
I would recommend working with Kioti to have your issued resolved, especially seeing the tractor is still under warranty.
Best of luck,
Nancy Wang,
Modine Manufacturing Co., Inc.
Welcome to Modine.com
Market Research Manager, The Americas
1500 De Koven Avenue
Racine, WI 53403-2552
P: (262) 636-1827
F: (262) 636-1424
E: n.a.wang@na.modine.com
Automotive Market Research Council (AMRC) Past President
Home
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
CRAFTSMAN TABLE SAW (A54757)
CRAFTSMAN TABLE...
2023 yamaha (A55758)
2014 Ford F-250 Ext. Cab Pickup Truck with Liftgate (A55852)
2014 Ford F-250...
2025 Swict 60in Bucket Skid Steer Attachment (A53421)
2025 Swict 60in...
2017 PETERBILT 579 (A53843)
2017 PETERBILT 579...
