PTO
   / PTO #1
Piedmont
NC, USA
JD 2520
I have to trim a couple of inches off the PTOthat came with my Herd spreader. I've never had to do that and loking for advice and/or suggestions. I want to get it right the first time.
I assume the tool of choice is a hacksaw?
   / PTO #3
I took my Herd Spreader PTO shaft to a local machine/welding shop and had them cut 2 1/2 inches off both halves so it would fit my tractor correctly. They had the metal band saw with the oil for lube as they cut. Cost me $12 Good Luck :p
Troy
   / PTO #4
Not a big deal, I started to cut one with a chopsaw, broke the blade, then on to a hacksaw, broke the blade, finished it with the cutting torch and a touch of the grinder... :D
   / PTO #5
If that's all you have, it will do the job. Less work though, if you happen to own a chop saw - or reciprocating saw (and a metal cutting blade)
//greg//
   / PTO #6
chop saw with an abrasive wheel.
AWESOME.
took about 30 seconds.
perfect cut.
Maybe I don't use that saw for much else, but it was still worth every penny. :D
find a friend/neighbor who has one.
   / PTO
Thanks for the feedback.
UNUSED MOWER KING ECSSCT72-72" HYD TRENCHER (A51248)
UNUSED MOWER KING...
UNUSED ALLMETAL K0311-10' GALVALUME STEEL (A51248)
UNUSED ALLMETAL...
2015 Peterbilt 320 Garbage Truck (A52377)
2015 Peterbilt 320...
2007 Ford Focus Hatchback (A51694)
2007 Ford Focus...
2016 Dodge Caravan (A51694)
2016 Dodge Caravan...
