PTO
Piedmont
NC, USA
JD 2520
I have to trim a couple of inches off the PTOthat came with my Herd spreader. I've never had to do that and loking for advice and/or suggestions. I want to get it right the first time.
I assume the tool of choice is a hacksaw?
I took my Herd Spreader PTO shaft to a local machine/welding shop and had them cut 2 1/2 inches off both halves so it would fit my tractor correctly. They had the metal band saw with the oil for lube as they cut. Cost me $12 Good Luck :p
Troy
Not a big deal, I started to cut one with a chopsaw, broke the blade, then on to a hacksaw, broke the blade, finished it with the cutting torch and a touch of the grinder... :D
If that's all you have, it will do the job. Less work though, if you happen to own a chop saw - or reciprocating saw (and a metal cutting blade)
//greg//
chop saw with an abrasive wheel.
AWESOME.
took about 30 seconds.
perfect cut.
Maybe I don't use that saw for much else, but it was still worth every penny. :D
find a friend/neighbor who has one.
/ PTO
Thanks for the feedback.
10 Lug Wheels Full Set (A57453)
10 Lug Wheels Full...
17395SFL (A61568)
17395SFL (A61568)
Trailmobile Van Trailer (A63118)
Trailmobile Van...
2025 Mahindra 6075 4WD Cab Tractor - 71 HP, Loader Ready, Ag Tires (A63118)
2025 Mahindra 6075...
(INOP) 2018 FORD EXPLORER (A59823)
(INOP) 2018 FORD...
2006 Ford F-350 12ft. Flatbed Truck (A61573)
2006 Ford F-350...
