PTO
Piedmont
NC, USA
JD 2520
I have to trim a couple of inches off the PTOthat came with my Herd spreader. I've never had to do that and loking for advice and/or suggestions. I want to get it right the first time.
I assume the tool of choice is a hacksaw?
I took my Herd Spreader PTO shaft to a local machine/welding shop and had them cut 2 1/2 inches off both halves so it would fit my tractor correctly. They had the metal band saw with the oil for lube as they cut. Cost me $12 Good Luck :p
Troy
Not a big deal, I started to cut one with a chopsaw, broke the blade, then on to a hacksaw, broke the blade, finished it with the cutting torch and a touch of the grinder... :D
If that's all you have, it will do the job. Less work though, if you happen to own a chop saw - or reciprocating saw (and a metal cutting blade)
//greg//
chop saw with an abrasive wheel.
AWESOME.
took about 30 seconds.
perfect cut.
Maybe I don't use that saw for much else, but it was still worth every penny. :D
find a friend/neighbor who has one.
/ PTO
Thanks for the feedback.
20' CONTAINER (A63745)
DBL STAINLESS STEEL SINK (A63745)
DBL STAINLESS...
HEIN-WERNER 1TON TRANSMISSION JACK (A63569)
HEIN-WERNER 1TON...
PALLET OF JOHN DEERE INSECTICIDE HOPPERS (A63745)
PALLET OF JOHN...
2013 FREIGHTLINER CASCADIA (A63569)
2013 FREIGHTLINER...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
