Is this safe? (PTO shaft/rotary cutter)
/ Is this safe? (PTO shaft/rotary cutter) #81
tthat would still give me about 8 inches of overlap on the shafts.
Depending upon how you gauge overlap, that might not be enough margin. Rule of thumb is that operating overlap should be 1/3 the length of the shaft.
  • Attach the implement to the TPH
  • Do not connect the PTO shaft
  • Start tractor on level ground
  • Raise implement to where implement transmission input shaft is exactly parallel with tractor PTO stub.
  • Shut off tractor
  • Measure from groove in PTO stub to groove in input shaft
When the shaft is installed, this is the point where it will be the most compressed (shortest). Raised any higher - or dropped any lower - and the shaft extends (less overlap). It's at the shortest point where the overlap should be 1/3 of the length. So if you have a 42" shaft, the overlap at that point should be 14"- because it will only get shorter from there. Most experienced folks get a shaft that's too long, then cut it to fit.
//greg//
Gregg, I used the approach you outlined and I have 13 inches of overlap on a 40 inch PTO shaft. I also tried moving the mower up and down as high as it can go (using a hydraulic top link) and it didn't seem to lengthen the shaft more than about 2 inches).
Everything worked great. Thanks all.
/ Is this safe? (PTO shaft/rotary cutter) #83
Well, 13 inches is a far safer margin than the 8" you first mentioned. But when I said raise and lower, I meant the three point hitch (TPH); specifically the lower lift arms. The hydraulic toplink should only enter the equation if necessary to
1. finish lowering the mower all the way to the ground (extend HTL)
2. finish raising the mower to the max carrying height (retract HTL)
//greg//
/ Is this safe? (PTO shaft/rotary cutter) #84
Bill I think you have the problem solved. Good for you!! You hung in there and figured it out.
MarkV
UNUSED IRANCH SEMI AUTOMATIC QUICK CHANGER (A60432)
UNUSED IRANCH SEMI...
2021 CATERPILLAR 306CR EXCAVATOR (A60429)
2021 CATERPILLAR...
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
500BBL WHEELED...
206320 (A57192)
206320 (A57192)
Toro MBTX-2500 Concrete Buggy (A54865)
Toro MBTX-2500...
