What would you change about your current John Deere tractor?
   / What would you change about your current John Deere tractor? #101
About the only thing that bothers me about the 4320 is the height of the ROP. I'd lower the ROP a foot or so.
I agree 100%. Sure wish my 4320 ROPS was about 4 -6 inches shorter.
Also, with the notorious fuel gauge issue when it indicates "LO FUEL", you no longer see your speed indication. This can drive you nuts when you're trying to maintain constant speed and you know you have about a half tank of fuel remaining.
   / What would you change about your current John Deere tractor? #102
Maybe it's different for the E-Hydro machines, but on my PR, when the "Low Fuel" flashes in the display, and I know it's not low, I just push the "Display Mode Button" and it clears the flashing so I can see the hour meter again. I wonder if it would do the same thing for being able to see your hours while moving on a Hydro.
   / What would you change about your current John Deere tractor? #103
I do have e-hydro. I'll try hitting the "Display Mode" button when Low Fuel is indicated and see if it works the same as your PR -- hope it does.
   / What would you change about your current John Deere tractor? #104
You can not check the engine hours if you have moved the tractor. Once you start it and move any at all it shows speed.
D.
I havent tested this myself, so I'm speaking from my rear end...but I thought that could be "toggled thru" using the Display Function button?
   / What would you change about your current John Deere tractor? #105
Don't believe we have a Display Function Button on our cabs... :(
   / What would you change about your current John Deere tractor? #106
Yeah you do. See option "D" in this excerpt from the owners manual. It should allow you to scroll through viewing the hours, speed, etc.
   / What would you change about your current John Deere tractor? #107
That doesn't look much like a 5425 cab to me. :D
   / What would you change about your current John Deere tractor? #109
Well no of course not:D, I was reading from the last 4 posts.
Ah... I started the whole complaint about the Hobbs meter, but it was a bit further than 4 posts ago. :D I also whine about the arm rests. My only real complaints concerning the tractor. I think its great when all I can find to complain about is a Hobbs meter and arm rests. :cool:
   / What would you change about your current John Deere tractor? #110
It's color!
J
2004 Ford F-550 4x4 Auto Crane 4004EH 2 Ton Crane Service Truck (A51692)
2004 Ford F-550...
1998 Blaw-Knox PF 150 Paver (A52384)
1998 Blaw-Knox PF...
2025 K1912 UNUSED Metal Livestock Shed (A53117)
2025 K1912 UNUSED...
2018 WACKER NEUSON RTSC3 ROLLER (A52576)
2018 WACKER NEUSON...
2003 GROVE TMS500E MOBILE TRUCK CRANE (A51406)
2003 GROVE TMS500E...
