2520 3 pt hitch arms rubbing - any alternatives?
   / 2520 3 pt hitch arms rubbing - any alternatives? #11
Get the newer style arms from your dealer. They will absolutely replace them at no charge. I, like many others have been through this. There are the proper part numbers and tech bulletin references posted by others from TBN.
My dealer was also very resistant at first - until I brought in the references from TBN. They still said no, but boom - when I picked up the machine after I got a snow blower installed it had the new arms on.
I too have the I-Match, tried washers, resetting the wheels etc, etc, etc. Even if you can "rig" something up - your machine will function so much better with the redesigned arms - you owe it to the tractor gods to do it.
   / 2520 3 pt hitch arms rubbing - any alternatives? #12
Here's a pic of the iMatch with the (new style) arms mounted normally. Old arms are below for comparison.
OK, for my solution, look at the pic (hope I copied it here).
See how this pic shows the 3 point arms mounted to the OUTSIDE of the I-match! Now, that pin that the 3 point arms are mounted to......Take that out, and put the end of the 3 point arm INSIDE of the 2 plates on the imatch. So, basically pull the pin and put the arms into the I match (not on the complete inner side of the I match, rather in between its layers).
Then put a proper pin back thru it, and Problem-Solved! Its really that easy. That moves the rear of the 3 point arms in about 2 inches on each side, so they now clear the tires with ease (even with HUGE tire chains on).
If anyone needs more clarification, ask away.
I know I had to get a different style pin to mount the arms this way, so it does require a few dollars in pins. They were like a pin with a steel plate welded on them or something if I remember.
Mine has been like this for 2 years now, and works great.
   / 2520 3 pt hitch arms rubbing - any alternatives? #13
Hiya,
If you do a search on the topic I posted a while ago "Calling all 2520 owners" you will find Phone #'s to call, DTAC #'s and some details about the process of getting replacements.
Tom
   / 2520 3 pt hitch arms rubbing - any alternatives? #14
I understand what you are saying (I think) but what you are describing is the normal method for hooking up to an I Match. From what I can see in the picture it is pinned into the center slots. Never seen anyone pin on an I Match outboard with regular link pins.
Steve
   / 2520 3 pt hitch arms rubbing - any alternatives? #15
I just went and actually looked at me, so I could remember what I did. :p
I looked, and I mounted mine on the INSIDE of the Imatch, not in the slot. I originally had them on the outside, and they rubbed alot.
I have 3-4 inches on each side now, so I'm not sure why you guys are having problems. I've got a pic on my camera phone.
I'll try to grab it here...........
   / 2520 3 pt hitch arms rubbing - any alternatives? #16
I ran those chains all winter last year, and they never once touched my 3 pt arms, because there is not a scrape on them at all. They don't even get close.
Are you guys actually adjusting your turnbuckles, so the arms are centered, and don't just slop all around? Mine are dead center, and are loose enough that the I match can move about 1/2 inch from side to side.
It takes 5 minutes to adjust them, but with the Imatch you never really need to readjust them ever again.
   / 2520 3 pt hitch arms rubbing - any alternatives? #17
Well if you are going to attach the pins in that manner I hope you have fitted the inside of the box tubing with bushings to leep from deforming and collapsing it.
I have a 4520 without this particular issue but for the sake of argument what if you need to attach an implement that is not I Match and the tire rubbing issue prevails? So I would still say get the updated arms to resolve the problem. This was an obvious mistake on Deeres' part and not much point in defending it.
Steve
   / 2520 3 pt hitch arms rubbing - any alternatives? #18
You betcha, I ground down a bushing so it was the perfect length and slipped it in the closed section of the Imatch, so the metal is supported, and then torqued the pins down. Its as strong or stronger than it was before.
So, WHAT attachments are going to make the arms hit the tires? They really DON'T hit them with NON-Imatch implements. They are very close, but they are still clear on both sides if you tighten the turn buckles. I would not be able to run the tire chains, but this issue is getting so blown out of proportion, its getting hilarious. I can't believe how many people act like the sky is falling. I fixed mine in like an half hour, and never looked back. Some people have called dealers many many times, and are arguing with them, and have wasted 10x as much time as me, and their problems are still not solved. I just took it into my own hands and fixed it myself.
All my attachments that are non-Imatch, I take and "Make them" Imatch compatible.
I'm not here to stand up for JD by any means, but I'm here to show that a little bit of positive effort goes alot farther than a whole bunch of wasted effort (on phone with dealer). My dealer is an hour away, and I REFUSED to haul my tractor in the road salt to have them look at it, so thats the main reason I fixed this myself. It was in January, and would be 4 months till the roads were bare. My baby will NEVER see road salt if I have my way!
Anyway, i hope this at least helps someone get theirs fixed, and we can all learn that its an option that the consumer can chose for a simple fix. :cool:
   / 2520 3 pt hitch arms rubbing - any alternatives? #19
Deadman,
I agree about converting to I Match, usually it is a simple fix. Any implements I build are I Match or drawn. Hands on approach is a good way to go, I use it often. I also agree that computers and cell phones are not going to solve all problems and yes there are lots of people who are fearful of trying things on their own and want to talk with someone else about them.
TBN can be a great resource to learn from though and it is not uncommmon for me to do a little research on a problem in a particular thread. Helps me learn something new. I have learned from quite a few other posters here as well.
Steve
   / 2520 3 pt hitch arms rubbing - any alternatives? #20
Just want to bring this back up to the top, so people can be aware of the easy fix...........
Hope it helps someone.:)
UNUSED RAYTREE RMRB72 - 72" POWER RAKE BUCKET (A54757)
UNUSED RAYTREE...
2018 JLG G5-18A (A50123)
2018 JLG G5-18A...
1995 GMC CHIPPER/BUCKET TRUCK (A54607)
1995 GMC...
UNUSED WOLVERINE BC-13-72W 72" HYD BRUSH CUTTER (A54757)
UNUSED WOLVERINE...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A55301)
UNVERFERTH 330 -...
UNUSED WOLVERINE GB-11-72W 72" HYD GRAPPLE BUCKET (A54757)
UNUSED WOLVERINE...
