grease gun tip stuck in awkward spot, ideas to get it off?
   / grease gun tip stuck in awkward spot, ideas to get it off? #11
If it is stuck on that well, unscrew zerk and all.
   / grease gun tip stuck in awkward spot, ideas to get it off? #13
I would find a bolt that would thread into it. Then use a stack of washers and thread in the bolt and with the washers pushing on the frame and the bolt pulling on the gun tip it should break it loose.
Chris
   / grease gun tip stuck in awkward spot, ideas to get it off? #14
Thread an eye bolt onto the tip, then tie off the eye bolt to the tractor and start up the tractor and extend the backhoe - the next sound you will hear id the tip coming off.
I want to know how you could tell he has a backhoe on this machine from the picture!!!
How about using a plumbers propane torch and heat the grease gun tip up and then try to pull it off?
Phill
   / grease gun tip stuck in awkward spot, ideas to get it off? #16
:DI agree with diamondpilot , and its probably going to be a fine thread, metric bolt you will need.. zman
   / grease gun tip stuck in awkward spot, ideas to get it off? #18
If its stuck from being under pressure and no where for the grease to go, I usually knock the pin back enough to expose the inside of the hole, and then it should loosen up.
   / grease gun tip stuck in awkward spot, ideas to get it off? #19
YUP, I had the same thing happen last week and went through the same pain :) push the tip down towards the nipple and wiggle until the inside releases and then it will pull off hopefully this helped.
   / grease gun tip stuck in awkward spot, ideas to get it off? #20
I like diamodpilots idear, grease gun tip thread are 1/4 npt or something like that. Have ya tried locking vice grips on the stubborn tip and pry on the 'grips with a pry bar, tire iron or what ever is handy?
2019 Deere 550K (A53317)
2019 Deere 550K...
500BBL WHEELED...
2005 Honda Accord LX Sedan (A59231)
2005 Honda Accord...
2013 BMW X5 AWD SUV (A59231)
2013 BMW X5 AWD...
2002 Kenworth T300 TMA Truck (A55973)
2002 Kenworth T300...
MURRAY PUSH MOWER (A58214)
MURRAY PUSH MOWER...
