grease gun tip stuck in awkward spot, ideas to get it off?
   / grease gun tip stuck in awkward spot, ideas to get it off? #11
If it is stuck on that well, unscrew zerk and all.
   / grease gun tip stuck in awkward spot, ideas to get it off? #13
I would find a bolt that would thread into it. Then use a stack of washers and thread in the bolt and with the washers pushing on the frame and the bolt pulling on the gun tip it should break it loose.
Chris
   / grease gun tip stuck in awkward spot, ideas to get it off? #14
Thread an eye bolt onto the tip, then tie off the eye bolt to the tractor and start up the tractor and extend the backhoe - the next sound you will hear id the tip coming off.
I want to know how you could tell he has a backhoe on this machine from the picture!!!
How about using a plumbers propane torch and heat the grease gun tip up and then try to pull it off?
Phill
   / grease gun tip stuck in awkward spot, ideas to get it off? #16
:DI agree with diamondpilot , and its probably going to be a fine thread, metric bolt you will need.. zman
   / grease gun tip stuck in awkward spot, ideas to get it off? #18
If its stuck from being under pressure and no where for the grease to go, I usually knock the pin back enough to expose the inside of the hole, and then it should loosen up.
   / grease gun tip stuck in awkward spot, ideas to get it off? #19
YUP, I had the same thing happen last week and went through the same pain :) push the tip down towards the nipple and wiggle until the inside releases and then it will pull off hopefully this helped.
   / grease gun tip stuck in awkward spot, ideas to get it off? #20
I like diamodpilots idear, grease gun tip thread are 1/4 npt or something like that. Have ya tried locking vice grips on the stubborn tip and pry on the 'grips with a pry bar, tire iron or what ever is handy?
*Selling at Royal Auction Tampa, FL Location* (A59231)
*Selling at Royal...
WHISPERWATT 220 DIESEL POWERED GENERATOR (A58214)
WHISPERWATT 220...
*Selling at Royal Auction Tampa, FL Location* (A59228)
Killbros 260 Seed Conveyor (A56438)
Killbros 260 Seed...
Ford F450 Bucket Truck with Altec AT200A Boom (A56435)
Ford F450 Bucket...
Grove 4x4 Rough Terrain Hydraulic Crane (A55851)
Grove 4x4 Rough...
