TC 35 New Holland and 52 Case VAC,LT25 Woodmizer logmill
Forks as opposed to a grapple will give you more lifting capacity with logs. You have a mighty large tree section. I am thinking "divide and conquer" that log with a chain saw.
I can't speak for your tractor, but I do know one thing for certain. I could slide my loader bucket under the middle of that log and promptly lift........the back wheels right up off the ground!
That is a pretty good sized chunk of lumber you got there. I think I could handle moving the sawdust as long as I could take it 1/4 yard at a time!
Go to the Forestry Forum and on the lower left of the screen is a tool box that contains a log weight estimator. My guess that dude will weight in at about 5,500 lbs. or more.
Ford 555 TLB, Caterpillar Motor Grader, Kubota L245, Ford LGT 125, FABTEK aerial platform
Trying to lift it could get expensive.
Seeing that picture reminds me of a tree stump I had dug out when I built a house. One guy twisted the dipper on his Case 580E BH digging the thing out. Then the guy that backfilled broke the loader bucket on his Case 450 crawler loader when he picked the stump up to load in his dump truck. The bucket made an eerie "ping" sound when it broke.
At the very least you could damage your front tires. Or it could be heavy enough that you'd break your loader.
How long are you going to keep us in suspense? Did you try? And what happened?
Looks like you might want to be careful with your turf tire sidewalls. While that particular set of scuff marks don't look too knarly, a nasty edge on a branch might not be quite so kind. Those tires are not cheap. My Grandpa learned that the hard way on his 8N after a scuffle with a barbed wire fence.
I have a Yanmar F24 which is just a little smaller than your B3030. I had a 42" diameter hackberry taken down a few weeks ago and I could barely push the main trunk after it was cut into 7' sections - even with weighted R1s.
