Shocks for my 2005 Dodge 3500 4WD SRW
/ Shocks for my 2005 Dodge 3500 4WD SRW #1
ddivinia
Elite Member
Red Oak, Texas
JD 5525 and 5093e Kubota SVL75
I have a 2005 Dodge 3500 Quad Cab 4wd short bed SRW. I have 80K miles on it and the shocks are starting to feel soft.
I don't have a suspension lift, but I do have bigger tires (315s - H2 tires).
What shocks should I put on it?
Thanks
Darin
/ Shocks for my 2005 Dodge 3500 4WD SRW #2
Bilstein's seem to be the best thing going for the heavier trucks. Cost a bit more but hold up better.
I have been looking at Bilstein and Rancho.
D.
/ Shocks for my 2005 Dodge 3500 4WD SRW #4
The best choice is the bilstiens in the HD version. I've heard nothing but 100% positive about them for hd truck applications. Just make sure you get the yellow hd ones and not the 5100's those are more for sporty handling than hd work. There's an online retailer that runs a special where you buy three get one free. Check it out.;)
Matt
/ Shocks for my 2005 Dodge 3500 4WD SRW #5
I second the Bilstiens. I put them on my CC diesel at 30K miles. Made an incredible difference in ride handling and stability over the stock shocks. I have 70K on the truck now. I will be doing another set of bilstiens when I do the leveling kit.
Also have heard good things about Ranchos, but I do not have any experience with them.
-Keith
/ Shocks for my 2005 Dodge 3500 4WD SRW #6
On my F350 It cam with Rancho's and they were good shocks, when I changed them I too added larger tires---LT 305's and at that time I installed the HD Bilsteins, I tow an RV that weighs in around 12,000 lbs. They do seem to handle evrything much better.
DevilDog
DevilDog
Which Ranchos did you have and which Bilstein did you go to?
D.
4 wheel store has their super shocking deal page:
Shocking Deals
Bilstein 4600s for $249.99
Lots of different models of each brand.
I might have to go by the local 4 wheel parts store and talk to them.
D.
/ Shocks for my 2005 Dodge 3500 4WD SRW #9
There's two shock's that do well on the Dodges. One is the Bilstein HD's (blue/ywllow), and the other is the 5100's (silver/black). The HD's are only for stock lift and suspension, and I believe the 5100's will work with a stock suspension up to a 2" lift on the front end. The 5100's are the better shock IMO. Dodge Cummins Diesel Truck Accessories Geno痴 Garage sells both of those shocks, and the 5100's are only about $5 more.
Good info - THanks, D.
/ Shocks for my 2005 Dodge 3500 4WD SRW #11
Thanks
Darin
I have bilsteins on my 2004 Ram 4X4 diesel 2500 quab cab.I put them on at 20,000 miles,I now have 80,000 miles they still work great.On edit,I would also change your front steering damper shock.I see genos garage has them for $79 bucks.coobie.
/ Shocks for my 2005 Dodge 3500 4WD SRW #13
Curious why you want a leveling kit?
I looked, but my truck sits level with wood, gravel in the bed, and when I hook up the 5th wheel.
With a leveling kit, wouldn't it be not level when the bed is full or if trailering?
FWIW, I had Rancho's on my last truck, the adjustable ones. Had an 11' Cabover camper. Never had to adjust the fronts after initial setting. Would turn the back shocks up when the camper was on. I had about 25k miles on them before selling the truck. Mine had knobs on the shocks; the more expensive version can be adjusted from in the cab.
-Keith
/ Shocks for my 2005 Dodge 3500 4WD SRW #14
Ok, here is a basic question. How do you tell when you need shocks? I think the front of my truck, at 129000 miles is getting bouncy.
What is best way to tell?
fwiw, mine is an '01 Dodge 2500 4x4 diesel
/ Shocks for my 2005 Dodge 3500 4WD SRW #15
I have a similar truck except 2500 and long bed. I also have 315's and H2 rims and I just upgraded to the Bilsteins and they are performing well.
/ Shocks for my 2005 Dodge 3500 4WD SRW #16
Robert,
I have a buckstop bumper on the way for the front of my truck. Will add about 300# to the front. still debating a permanent winch verses a multi mount portable, either way looking at another 100#. Also plan to go up a size tire to 285-70-17s.with all of this I am going to install a cognito "leveling kit". It will replace the upper control arms and increase suspension travel (better ride) while allowing me to compensate for the extra weight and larger tires. I plan to keep the stock rake you describe by putting 1 1/2" spacers in the rear. Already have air lift air bags which raise the rear about an inch with just 10 PSI.
Thats the plan, when I get it done I will post some pics. -Keith
Robert,
I went with a warn multi-mount so I could go front or rear.
I guess I will be calling Genos and ordering some Bilsteins.
D.
/ Shocks for my 2005 Dodge 3500 4WD SRW #18
Interesting.
I have 285-16's(Cepek's). An extra 1.5" in the rear would really make me high for the 5th wheel. As it is the axles are flipped. And, after knee injuries, it is hard enough for my wife to get in/out of our basically stock truck.
I would be interested to find how the leveler improves the ride. I found the weight on the kingpin, even just from my 7500lb 5th wheel, makes my truck ride like a Cadillac :D
I have been really happy with Cepeks' from 4 Wheel Parts...
What are your thoughts on the airbags? Our 5th wheel RV is relatively light at 7500lbs. It just levels the truck out. Have run a 4400 mile trip to Texas and it did well, but I wonder if air bags might help ride quality.
Robert,
/ Shocks for my 2005 Dodge 3500 4WD SRW #19
My feeling is if you need air bags you need a bigger truck. They are a band aid to mask something. Many like them but I am not a fan.
Chris
/ Shocks for my 2005 Dodge 3500 4WD SRW #20
I put the blue/yellow (standard height) bilsteins on my 2500/cummins 4x4 - I got them off ebay much cheaper than i found anyplace else (even with shipping)..
Brian
(1) 300 GALLON & (1) 330 GALLON POLY TOTES W/CAGES (A60432)
(1) 300 GALLON &...
2014 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2014 FREIGHTLINER...
INGERSOLL RAND G25 GENERATOR (A58214)
INGERSOLL RAND G25...
BOAT TRAILER (A60430)
SHOP MADE MANIFOLD TRAILER (A58214)
SHOP MADE MANIFOLD...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
