Hitch 'N Plow
/ Hitch 'N Plow #21
If I could get someone from around mid-Michigan who wanted it, I would build one roughly based on the design elements I talked about. You pay for materials and I'll make it and we'll test it out. You take the product when we're done.
I don't really need one. Eight years ago, I had a 1300' driveway and owned a 6 foot 3pt blade. Today I have about a 100' or less drive and only a 5' blade. Probably a 7 or 8 foot 3 pt blade would be good to pull behind a SUV or truck.
/ Hitch 'N Plow #22
I am only looking to plow about 80' of cement driveway in the suburbs at my Dad's during the snow. Nothing else. No unknown objects to hit. Not even going to get to 5mph.
Just looking at it as an alternative since I already own this blade to a more expensive product like these.
Home Page - Snowman Snowplow
SuperPlow The Best Personal Snow Plow
Getting the plow from place to place will put the greatest stress on it. I am not so sure its meant for transport but just using around your place.
Chris
/ Hitch 'N Plow #23
A company in Florida selling something to blade snow???? That always leads to fun results. :) Not for the owner of the new gizzmo, but for those seeing the results. :)
--->Paul
Taken from the schmidt products website.
"Bob has a BSME from Lawrence Technological University, an MSA from Central MI University, and has over 20 years experience in development, sales and marketing of fuel systems and propulsion systems for powersports, automotive and military applications. He currently uses this experience to represent several company's to market their products and services in the US and Europe. Bob develops new consumer products and has four patents, several patents pending and two trademarks. Click on Bob's resume link for more details on his experience and contact Bob if you have any interest in the company's he represents or products he has developed. Email: Bob@schmidtproducts.com. "
I assume the ole boy has seen some snow in his time. Just because the company is in Florida doesn't mean he is. And we all know that nobody from Florida is smart enough to build a snow plow....:rolleyes:
/ Hitch 'N Plow #24
Chris
Transport really wouldn't be a problem, you could just put a metal strap or chain to help hold it up like a strap used to hold a trailer ramp/gate up.
/ Hitch 'N Plow #25
That is probably true. A Woods HBL96-2 (96" medium duty rear blade) weighs 562#, put that on a 63# adapter (out 2-3 feet from the hitch) and it will give you 8-900# of static tongueweight. Not good for driving down the road on many 1/2 ton vehicles, but it should be ok on a heavy hitch.
Aaron Z
/ Hitch 'N Plow #26
I think the main point is to not allow the implement to bounce up and down supported only by the winch cable. If you secure it during transport with a 1/8" x 1" or 1 1/2 " steel strap it will not bounce up and down and should be fine.
/ Hitch 'N Plow #27
Has anyone out there tried this?
http://www.schmidtproducts.com/7501/7801.html
I am thinking it would be useful to take my rear blade over to my Dad's and snowplow his driveway, instead of loading up and taking the whole tractor.
I bought one at the beginning of winter 2009. Its Great. I have a 800' driveway and it makes quick work of a tedeous job. I'm in NE Ohio and it takes out 10" of snow in no time. I am literally "hooked up, plow, and parked in the warmth of my Trailblazer in 30 minutes. Spent less than $300 for everything. Wish I bought it 5 years ago.
/ Hitch 'N Plow #29
Having a limiting strap or travle safety chain won't stop it from bounching... it will just take the load off the winch... the blade is still going to bounch around a bit.. I ended up having my hitch modified with some gusset plats to make it stronger.. I ended up bending it to the left and right a couple times... worke great last winter... I know work for a landscape firm and we take the plow trucks home during the winter.. sold mine hitch n' plow last spring for $400..
/ Hitch 'N Plow #30
I've had this in mind for a while... though I plan to use it to grade my driveway and trail...
I found this;
T-Point lift vehicle 3 point hitch
It would give downforce, but I worry about the length and leverage that length would cause. I'm not against replacing my rear shocks with rigid bars...
Here's my rig;
Also, I worry about the height required to get proper angles... I think my hitch is 24" off the ground if I remember correctly... or maybe it was 29". I measured once. LOL
/ Hitch 'N Plow #31
I've owned a Hitch-N-Plow from Bob Schmidt for 3 years now, I know all it's little quirks. Bob says NOT to push snow with it, you can take that to the bank because you will either break the cable on the winch, or break the hitch-N-plow right where the single tube goes into the "Y". I've broken mine 3 times (easily fixed with some steel and a welder), once this winter and it was from pushing going backwards. I'm running a 1500lb MasterLock ATV winch, it works well but I've replaced 3 winches in 3 years and the MasterLock seems to hold up the best (Walmart...$75 out the door). I do keep a spare winch on the shelf because if it does FAIL, you're not plowing without it. I bought a wireless remote to run the winch which isn't expensive, and I'm not running wires from the winch to the inside of the cab to control the winch. Bob says up to a 6ft blade, I'm now running a 7ft on the back of a 2013 Ford F-150 4x4, last year I ran a 6ft plow but replaced it last summer with a 7ft. As mentioned in this thread, having a place to deposit the displaced snow is a MUST. I clear my drive and all of my front yard in the beginning. As winter progresses, I fill my front yard with displaced snow. Last year by winters end, I was just started running out of yard because of displaced snow. In my opinion, the design is a solid concept and works as advertised as long as you follow Bob's directions for use to the letter. It is built with LIGHT steel square tubing, but is welded together very solid. I don't like the fact that the winch is SLOW in raising and lowering the blade, but it's better than buying a $4000.00+ plow for my truck. If all you're going to do is move snow or grade a long drive, no problem. If you hit a solid object of any kind, it will break so just keep that in mind. You do have to LEARN how to use it as well. If your plow vehicle nose goes down in a dip, the blade will go up unless you spool out enough cable on the winch so the blade will float across the ground with the rises and dips. This adds time when you have to raise the plow because you have to spool in the excess cable before the blade starts to rise. I do like mine, and it performed great last year when I had a massive amounts of snowfall. Another tip, angle the rear view mirrors to observe the blade. My 7ft plow sticks out 1ft on each side of my truck so I can see it. The 6ft plow, I couldn't see it behind my F-150, but I could see it behind my Ford Ranger.
/ Hitch 'N Plow #32
I am glad you like my Hitch 'N Plow invention. I appreciate the feedback and I think the clarification you have provided will be helpful to other people using this product to plow snow. I licensed this to Behlen Mfg. in 2014 so they are now producing and distributing. They produce 3-point implements so this is a great because it helps them sell more implements. They offer Hitch 'N Plow (without winch and blade) on Amazon for $199 with free shipping if you are an Amazon prime member. Also available on Amazon Canada now. I am looking for videos if anyone has any good shots of Hitch 'N Plow plowing snow. I would like to get permission to use these to create a new YouTube video. Go to hitch-n-plow.com for my contact info. Also, if you have any questions you can email or call me directly. Best Regards, Bob Schmidt
/ Hitch 'N Plow #33
Bob...I just hope Behlen can weld this thing as well as your original welders did. That was aircraft grade welding and is bullet proof. I also noticed an engineering revision from welded studs to bolt on pins. The welded studs on mine have not offered to even MOVE let alone break so I cannot speculate why the change was made. I don't feel the bolt on pins would be a problem either, and a lot easier to fix should they bend or break but that hasn't been an issue for me.
I wouldn't mind doing a video for you, but we gotta get a decent snow AND I gotta recruit someone to freeze their tail off first. Maybe I can get one decent storm to show what this thing can really do. I would pit it against a front mount any day of the week as far as plowing large volumes of snow but the only drawback is that it is SLOWER because of the winch speed. I thought about using a linear actuator rated for 1000lb push/pull to replace the winch but that would create problems I'm not willing to tangle with, not to mention the price of an actuator being in the $300-$400 price range.
/ Hitch 'N Plow #34
I would think a rear facing camera would be necessary to use.
/ Hitch 'N Plow #35
I would like to offer two changes here. One is the cable clamps. In post 31, he has the clamps all facing the same way. I suggest the middle one to be flipped 180. My dad has taught me to alternate the location of clamps as its what he learned in the army. Second is with the backblade down all the way on level ground, I suggest adding a chain to take the tension off the cable and as backup if the cable breaks so it doesnt cause a catastrophe on the road while either backing up or driving forward.
/ Hitch 'N Plow #36
Don't alternate clamps. All the same, facing the right way. The U-bolt crimps and weakens the cable. You want the U-bolt side closest to the end of the cable..
And for those who can't remember which way the clamp goes:
Bruce
/ Hitch 'N Plow #37
well -- call me shackled- I stand corrected - the right way to clamp.
thanks bcp
/ Hitch 'N Plow #38
Bruce
Best way I was told to remember this in a rigging class once was "You never SADDLE a dead horse". So the Saddle never should be over the "Dead" end of the cable.
/ Hitch 'N Plow #39
using the "SuperPlow EZ". It uses a Meyer Blade (pulling instead of pushing) with electric hydraulic controls for up and down to be pulled behind a car / SUV / Truck. Connects to the regular hitch. Can also push snow - going in reverse. Have it attached to 3 point hitch on tractor and lift with the tractor hydraulics. Works great and only one pass is wide enough for a delivery truck to get through. Unfortunately seems that the company is no longer in biz? Phone did not connect and search on the net did not bring up details. Here is a you tube film on how it works: https://www.youtube.com/watch?v=5kn5IlTryIA
/ Hitch 'N Plow #40
Would be great for tractors without 3 point hitches.Nice idea.
2013 Jeep Wrangler 4x4 SUV (A59231)
2013 Jeep Wrangler...
2019 CATERPILLAR 950M WHEEL LOADER (A60429)
2019 CATERPILLAR...
UNUSED KJ K2223-23' X 22' DOUBLE GARAGE METAL SHED (A60432)
UNUSED KJ...
1992 DFI PULL SPREADER (A57192)
1992 DFI PULL...
1977 Heil 6,300 Gallon T/A Tanker Trailer (A59230)
1977 Heil 6,300...
2019 CATERPILLAR 239D3 SKID STEER (A60429)
2019 CATERPILLAR...
