Chipper Wallenstein BX42 woodchipper
   / Wallenstein BX42 woodchipper #11
How would the BX42 do with hardwood (oak/maple/ash) bark? I bring wood in as large chunks/rounds and make a rough "pile" on which they sit for about a year. Then I split those into pieces my stove will accept in year#2 and stack in the shed for another 10-12 months. At splitting time I get lots of large pieces of bark (sometimes 10" X 16") falling off. I like to chip this up to make mulch for the flower beds (not the ones close to the house!). I find myself breaking the large pieces of bark into strips 3"-4" wide to get through my small (5 horse) chipper. Would a BX42 help or would I be better off with the Wally BXM32 chipper/shredder ?
Frank
   / Wallenstein BX42 woodchipper #12
Haven't tried just "Bark". I've got lots of Pine Bark arround as it does the same as yours... falls off the dried splits and just piles up in big chunks.
I'll have to try that this w/e..... Home made "Bark" for cover... I like it!
Cheers
Tell ya what.... you come buy one from me and if it does not work as well as you would like it to, I will refund all your money!
Thanks, everyone. Rick, are you serious about your offer? I might just take you on that.
Do you have a BX42 in stock?
   / Wallenstein BX42 woodchipper #14
I have a BX42 that I run on my Kubota B2620. Initially, I had problems with it clogging on small flexible branches, and stuff that was mostly green leaves. I found that the cutter clearance was not set right from the factory. ( I think they set them pretty wide when new because of paint, and run in, etc.) Anyway I adjusted the clearance per the manual, and haven't had any further trouble. The chipper is rated at 1000 rpm, so I have tried it with the 960 rpm on the rear pto that my tractor offers. That will spit grass, weeds, and about anything else small that you can think of right through there! You lose torque for the larger stuff though. I did try it that way by tossing armloads of weeds in there, and they went through fine.
   / Wallenstein BX42 woodchipper #15
I do the same - run it at 960 for the little stuff and I doubt you will clog. The only time I ever clogged mine was at 540 and lots of leaves and small junk.
   / Wallenstein BX42 woodchipper #16
Well first full day with the BX42. What a Beast on my B7800! 2100rpm on the tractor (480rpm on the chipper aprox).
Filled the bed on my truck 4 times (heaped), emptied on my Hops field for suppression of the weeds, with out any issue.
I had figured the wood limbs I had laying around would be a full day's work, but this little chipper ate and ate and ate in nothing flat. Just load, get her started on the limb, then go grab another... repeat. It was more work to empty the truck bed than it was to chip the wood.
Ended up getting the chain saw out and cutting more! and ended up cutting and chipping, cutting and chipping.
But my @$$ is sore today, as are my hands... I need to toughen up some I guess. These toys sometimes just work me too hard as they do so much work they drive me to accomplish more and more than I had intended in one day.
Love my Wallie BX42!
   / Wallenstein BX42 woodchipper #17
Not a toy my friend. I too learned real quick that gloves are a necessity with this machine as the initial feed vibration from a large limb could tear the calluses off of my hands. The BX42 is a plain and simple good hard working machine.
   / Wallenstein BX42 woodchipper #18
Oh I had gloves! But I learned to keep fingers out from "BETWEEN" branches!!
Crack! and they slap together like a whip, and fingers in the way are battered and bruised instantly!
But the little BX42 is a BEAST! at eating wood!
Amazing how much work I got done over both Sat and Sun. More than I could have imagined. Fantastic... now if my hands heal by next w/e's work....:D As I still have another acre of downed tree's and limbs. Probably a Month or more of w/e's, then I'll have to wait for next year as with the leaves growing and brush growing rapidly.... I'll not be able to keep up. Besides the grass, garden and such will begin to take over the time I have.
Thanks for all the support and info on the BX42 and encouragement to pick it over the others. It's a remarkable piece of equipment!
   / Wallenstein BX42 woodchipper #19
I read your comment about the hands and other soreness. Hopefully that will pass quickly and you'll be ready for next weekend! Did you get a chance to try some of the big "sheets" of bark? Sounds like you are plenty busy without my silly requests!
Good luck.
Frank
Cheers
   / Wallenstein BX42 woodchipper #20
DOH!!! Sorry, next w/e I'll have to make a list.
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2021 TAKEUCHI  TB260 (A58214)
2021 TAKEUCHI...
2018 Dodge Ram 3500 (A53317)
2018 Dodge Ram...
2022 Ligchine Spiderscreed Concrete Screed (A59228)
2022 Ligchine...
Agri-X 5' 3pt Mower (A53317)
Agri-X 5' 3pt...
iDrive TDS-2010H...
