Blade Clearance from Ground
   / Blade Clearance from Ground
Please explain; If the answer to my problem has been given I need help in understanding it. Kenny D's picture should be enough but I still do not grasp it.
   / Blade Clearance from Ground #12
If the side links are attached to the holes closer to the tractor, then the arms will lift higher.
   / Blade Clearance from Ground #13
Out of the JD 2320 Operators Manual
Adjusting Lift Capacity and Height
Draft links (A) and lift links (B) each have three different positions that can be used to change lift capacity and height capacity. Tractor is shipped from factory with both links in mid position.
Adjusting to inner hole (C) on draft link and upper hole (D) on lift link will provide maximum lift height. Adjusting to outer hole (E) on draft link and lower hole (F) on lift link will provide maximum lift capacity. Adjust links as necessary for your implement.
Gizmo; Thanks for the explanation and picture. The picture sure helped.
I think you have solved my problem. I just did not get much additional clearance tinkering on the top. I will let you know how it works out.
Gizmo; My JD 4300 has a different set up than the one you posted.
When I shortened the LIFT LINKS as far as they would go and then shortened the center link most of the way I was able to get the rear of the rear blade 10" off the ground. If possible I would like to get another 4" of lift height at the rear of the blade. Is the extra height necessary or unreasonable?
I do not have a Hydraulic center link but I might be able to change to lift links I can shorten a little more than the ones on the tractor.
OR new Draft Links with holes in different locations OR Different Sway Links because when I tried swapping position of the sway link and the Lift Link, the sway links would not reach (were too short) the rear position hole on the Draft Link. The new position of the Lift Link (in the hole for the Sway Link) was a couple of inches higher as shown in photo # 2.
Hopefully I have attached a picture from the Operator's Manual that shows my setup.
   / Blade Clearance from Ground #16
Stuart,
The extra height is only necessary if you need the extra height. In other words, it is different from one application to the next. If you need to drive up and down steep banks, through ditches or other unlevel ground the extra height may be necessary - otherwise you will unintentionally dig a ditch. If you primarily run on level ground I would think 10" is pleanty of travel. Again, it's subjective and individual.
Just my opinion:)
   / Blade Clearance from Ground #17
We need pictures of the Frontier RB 1172 attached to your tractor in the total up, midway point and total down, with a couple different angles with the camera. Could it be the Frontier RB 1172 is too big for your tractor? As a standard post hole digger is almost too big for the 2305.
Compact1; I have had the same thought and most of my property is flat with slight slope except for the ditches I want to be able to clean using the blade in a tilted fashion. In order to use the tilt function I need the extra height on the blade.
Gizmo; I have some photos I can post after I go thru them. The 4300 is rated for the RB1172 blade. My Bushog Squealer weighs more and the 4300 has no problem raising it high enough to go over ditches so I do not think that is the problem.
If you look at the picture of the lift arms I posted above the closer arm is raised higher than the other because I moved the Lift Link closer to the tractor. The other arm is in the original position. I would need longer anti-sway links to make this configuration work. When I did get my sway link attached it was too short and hit the inside of the tire.
   / Blade Clearance from Ground #19
I don't get it. Those lower arms look 2' off the floor. If your blade sits level, it should be plenty high. No?
Jim
   / Blade Clearance from Ground #20
Jim
Yeah, like pointing to the moon.
2013 FREIGHTLINER CASCADIA SLEEPER (A52576)
2013 FREIGHTLINER...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2016 Ford Fusion Hybrid Sedan (A50324)
2016 Ford Fusion...
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
1999 FORD F550 BOX TRUCK (A52577)
1999 FORD F550 BOX...
