At Home In The Woods
   / At Home In The Woods #1,261
Obed - You may want to think twice about that when living so close to the woods. Critter like skunks and raccoons have been known to use them looking for food. Big enough and small skinny burglars can squeeze thru them and gain entry to your house.
Owning pets is a commitment that requires making sure you care for their personal needs no matter what time of day it is.
My neighbor installed one in his basement door and so far has been visited with a skunk and other neighbors cats helping themselves to his cat's food.
They do make some fancy dancy ones that the pet has a keycollar to unlock the pet door to keep the riffraff out, I'm sure they are cheep!!
tom
   / At Home In The Woods #1,262
We have built-in cat doors in our house. We have two decks, a screened in deck and a open deck. Neither has steps going down to ground level. The screened in deck cat door is available all the time. The one to the open deck has a little swing door I made that can be locked. It is closed at night. You can see the little padlock for it in the picture, those cats are crafty (but we can leave the key in the lock :laughing:). The white foam is for insulation and to keep the wind and rain from blowing the door in (and getting things wet) when the door is locked.
There is also a pictures of that door from the outside, and a bad close up of how it is framed. Basically, we framed with 2x4's. We bought two brands of doors and make the size such that the door can be changed out without having to re-do the trim for the door. Caulk fills in the little gaps. So the door can be replaced without ripping up any trim.
The covered box by the cat door has a cat-5 that will someday go to electronics I'll be making. I'll design a 130 KHz loop antenae that is in the trim around the door, and run an RF ID so we know which cat is using the door. (quick home automation digression)
The bigger view of the door (the one that include cats that were curious as to what I was doing) shows why we did the doors separate. We wanted the full view window doors (Full Light Door). The cats like them too- they can sit and watch the outdoors. The "shelves" are cat steps. If we put a block at the bottom, when they get old they can still climb up to that one counter.
There is also a shot to the screened in deck door (you can tell the deck is covered and see the cross pieces for the screening). Again, the build in door make the people door very nice. Another box for RF ID. This approach is spousal approved and the big door - little door gets a very high "cute" rating from the same judge.
Finally, there is a shot of the people and cat door into the snoratorium. There is a similar set into the master bedroom. This lets the cats rome around at night while maintaining the sound isolation of the snoratorium (used in the unluckily event of snoring). Again, the big and little doors rate very high on the spousal approval scale (as does the snoratorium). The cost of triming the cat door is _more_ than the people door :confused2:. Exact same cuts, but the smaller pieces make it difficult and there has to be some trim wood put in (whereas the people door the trim is part of the door). The 2x4's are thinner than the wall, so the box has to framed out. Can't find a picture of a door before framing, I'll keep looking.
I would imagine that the same process could be used for a dog door. It is a big win to have the cats able to outside on their own. They are protected from the world since they can't get to the ground. The door we lock each night to the open deck keeps any deck climbing critters out. The door to the screened in porch is also a bit win since when it's 3:00 AM and the cats want out they can go listen to the frogs on the pond from that porch. Finally, the look of it all is very nice and unique compared to the critter door _in_ the half light people door.
Hope these pictures help you make a decision. I like this style better than the half light door with user added pet door. The pets can see out. Since you are in the fog of construction with a billion things to do, maybee you figure out how to do one like this. We have other cat features in the house, but I'll skip those so as to keep on todays topic.
Pete
We have built-in cat doors in our house...Pete
Pete,
The pictures are a tremendous help. We've been trying to figure out how to prepare the house for installing them. Thanks!
Obed
Mud Mud Mud!
Last week I finished cleaning the footers in preparation for the brick installation. Then we got an incredibly heavy rain on Monday.
attachment.php
Our footers got covered with mud again. When it happened the first time after the rains that flooded Nashville, I figured that was an anomoly. But less than 2 weeks later, we got another unbelievable downpour. Now I'm back to the drawing board.
I'm in this circular loop. It's like a bad movie. The footers are lower than the surrounding dirt. I can't backfill the footers to make water run away from the house until the brick is laid. We won't get the rain gutters installed until after the brick is 1st installed, and after the soffits are installed. But everytime I clean the mud off the footers, it rains and covers them with mud again.
It became obvious that I need to give the water a path to drain away from the footers.
attachment.php
So this evening after work I dug a trench. After the brick is laid, I will put a drain tile beside the retaining wall and will put a drain pipe in the trench to drain the water that gets into the drain tile. I put a level on a board to measure the slope to make sure I get at least a 1/4" per foot drop. My level has a mark etched into the glass that shows the 1/4" per foot drop.
attachment.php
   / At Home In The Woods #1,266
Glad the pix helped, sounds like there was spousal approval too.
I had to dig and clean off the footers for our garage 4 times during construction before the block was placed there. Ditch looks good, I think you've got control of this drainage problem even if no one can control the weather.
I've got a project I started in October that has been waiting for good weather to finish. I've had a few interruptions that didn't help.
The day you can declare that the project is indeed out of the mud is a great milestone in your home's construction. It's astounding how much infrastructure is buried in and around a properly constructed modern house! Thanks for keeping everyone posted, and you'll really be glad you have all these pictures of this big event in your life.
Pete
   / At Home In The Woods #1,267
I remember well the night I came back to the house in CA after being in OR for a week.
The dogs went crazy after entering the house and I soon discovered that a raccoon was in the house after entering through the dog/cat door. Knowing that even a medium raccoon can maul a large dog pretty thoroughly I put the dogs back in the car and contemplated how to dispatch the raccoon.
First discovery was that even though the .22 target pistol was in the house, all of the .22 ammo was in Oregon. After thinking and searching the available tools boiled down to a .45 or a WWII bayonet --about 18" long and sharp enough, but seemingly a bit short.
Finally settled on the bayonet as less likely to put holes in the walls and spatters of blood all over.
It took 20 minutes of crawling on the floor and threatening with the bayonet, while the raccoon threatened right back, to get it to go back out the dog door.
A. You want one that only your pets can activate.
B. The pet door should not be from the house into the garage, as much as the garage would form a convenient antechamber for the pets. The door will compromise the fire barrier required between the house and the garage.
C. For general, around the house wildlife repellent, a squirt bottle full of ammonia is hard to beat -- almost nothing smaller than a bear will attack if you are spraying it with ammonia and there are no blood stains to clean up afterward.
   / At Home In The Woods #1,268
I had dirt cave in before I got my footer drain installed, so I had to dig it all out by hand. Fortunately not twice. hope you beat the next rain.
... and I soon discovered that a raccoon was in the house ...
CurlyDave, That's an interesting story.
When we lived in Charleston, SC, the bottom floor of our tri-level house got flooded by Hurricane Hugo. We tore all the sheetrock and carpet out of the downstairs to let things dry out. There was a gap in the wall where the HVAC ductwork came into the house from the crawl space. One evening we found an opossum in our kitchen eating cat food out of the cat's bowl. We actually were amused. When the opossum saw us, it waddled off and exited through the gap in the downstairs wall. Opossums are very slow moving creatures.
On another night, the wife saw the opposum sneak through a bedroom door upstairs. She searched the room but couldn't find the opossum. After she got me involved, I found it hiding behind and under a desk. Armed with a broom, I chased the oposum downstairs and out the front door.
Later, one night while in bed, my wife rolled over to find herself face to face with the opossum. The opossum was snooping through the waste basket beside the bed. While I slept, my wife chased the opossum downstairs and cornered it. By now the wife was fed up so she started beating the poor opossum with the bristle end of the broom. The opossum stayed in the corner and hissed at her while she accosted it. She then started feeling sorry for beating the opossum. So she subsequently trapped it inside a cardboard box. The opossum hissed at her but did not put up a struggle as she boxed it up. She put the box and opossum into the car and took the opossum down the road a couple miles and let it go. That was the last we saw of the opossum.
We discovered that the opossum had been sleeping in our master bedroom closet in a box that contained our winter sweaters. The box was covered with opossum hair. The opossum had made itself a nice cozy bed. We aren't quite sure how long the opossum had been living in our bedroom with us; it was at least a few days. The opossum seems to have been house broken because we did not find any opossum excrement in the house.
Obed
   / At Home In The Woods #1,270
With all the talk of cleaning the footers I happen to notice that my neighbors house which is brick the footer is above ground all around his house with the lowest (to ground level) being about a foot. It is painted cement. That makes sense to me rather than burying brick below ground level. Common sense tells me that brick and mortar are porous and if water can get behind the brick it could lead to mold or maybe damp area which would attract termites. Just my 2「.
Guy
1999 Thompson H3 S/A Towable Vacuum Water Pump (A59228)
1999 Thompson H3...
skeleton / rock bucket (A56857)
skeleton / rock...
2018 ALLMAND MAXI-POWER 45 GENERATOR (A58214)
2018 ALLMAND...
PARTS ONLY - Has Title - 2023 Ram 1500 Classic Pickup Truck - Hemi 5.7L - Automatic Transmission (A56438)
PARTS ONLY - Has...
2022 Brush Wolf 4800X Severe - Duty Excavator / Backhoe Brush Cutter (A57024)
2022 Brush Wolf...
1994 SHOP MADE ENCLOSED TOOL TRAILER (A58216)
1994 SHOP MADE...
