hp requirements for disking
   / hp requirements for disking #11
Marsh,
I pull a 6' disk with a JD 2210 in heavy soil. The disk is older, adjustable and fairly light. It needs to be weighted down to do much digging. The tractor is somewhere around 18hp drawbar, and has filled tires and plenty of suitcase weights up front.
In high gear, the tractor will NOT pull the weighted disk at it's most aggresive/angled setting. Moving the disk down to a middle/angled setting the tractor will pull the disk in high gear, uphill slopes are still a problem though.
In low gear the tractor will pull the disk fine in any setting, any slope, but low range does not have the ground speed for the disk to fling and turn the soil over properly.
Typically new disking takes several passes with small bites. For the smaller areas I'm working now a tiller works much better.
In my case, I'm pretty sure 5 more hp disking would be a big difference. More HP would be even better. 20 more HP and I'd probably start wanting a bigger disk.
Hope that helps.
Joe
   / hp requirements for disking #12
The implement brochures give widely varying info on how much hp is needed to pull a disk, generally from 5 to 10 hp per foot, which is quite a variation. I'm shopping for my first tractor, for a five acre old walnut grove and building site. Soil is black adobe tending toward dg. I will mostly be rough-cut mowing and moving material around with a FEL, but think I will also want to disk. Terrain is nearly level. Do I really need 40 hp to pull a 4-foot disk? Is that total hp or PTO hp? I'm leaning toward Kubota, JD or NH because of proximity of dealers. Any thoughts? Thanks, NE
If you want to do this estimate scienterrifically, here's some info
http://www.tifton.uga.edu/eng/Publications/farm tractor.pdf
Discs need two things to work effectively: weight and speed. Heavier is better so you need to add weight to small, light weight discs, especially if the soil is hard and gravely. For example, I plow my 6 acre hayfield (very gravely) with an old 6.5 ft Towner offset disc with about 500 lb of added weight (4 concrete weights strapped to the frame of the disc).
The disc alone probably weighs 700 lb, so my 2008 Mahindra 5525 (54 hp engine, 45 hp pto, 2WD, gear tranny) is dragging about 1200 lb plus a tire drag to bust up the clods.
Speed: I pull that disc 5-6 mph and make several passes at right angles to get the hayfield prepared for planting.
I probably could pull this disc/drag rig with a 40hp (engine) tractor but more hp is usually a good thing to have in your back pocket.
   / hp requirements for disking #13
As the guys said before it comes down to traction. I pull a 11' disc at the local go cart track with my 28HP Jinma but there is no grass, it pure dirt and my tractor is 4 wheel drive with R1 tires and weighs 5,200# with me on it. They have trouble moving it with a 35HP John Deere with R4 tires and not much weight, maybe 3,500#.
My personal disc is a old Ford 6.5' 3 point unit and is a much better fit for all soil conditions.
You need weight, good tires like R1's, and a properly set up disc.
Chris
   / hp requirements for disking #15
The previous comment on Ford n's is right on the mark. The big difference is fuel consumption. I used a 8 ft pull-type on my 1951 8n last year and had the ground ready for planting after discing (3) times. Also, each time discing was less because the cut was wider. With a 6.5 ft, 3-point that I used the previous 18 seasons, it always took 5-6 times before the ground was ready to plant. This year again, my ground is ready for planting after (3) passes with the pull-disc. The bottom line here is that the gallons of gas used with the pull-type disc is well under half what it always took with the 3-point. I now have a strong dislike for 3-point discs for this reason, and I dont think they are a good tool for any purpose. If your jobs are too small for a pull-type or transport disc, you would be much further ahead with a tiller than a 3-point disc. I apologize in advance to all the 3-point disc folks that I usually rile up with comments like these. I just think that these days, fuel is too precious of a commodity to waste with a 3-point disc. Remember folks, it is possible to get the job done, doing less work. Working the ground extra deep in some spots and not even touching it in others allows the 3-point to do more work yet take longer to prepare the ground for planting. Physices does explain it, you just got to go a little past the first chapter of the book.
   / hp requirements for disking #16
sso/dd (same snake oil/different day) Doesn't your balloon ever land? Maybe you should have a pull-type hitch installed to that three-point disc you have....so that you can save some fuel?? :laughing::laughing::laughing:
   / hp requirements for disking #17
What gets me in all of these disking threads is most everybody leaves out weight, size of disk blades and type of disk that they are talking about.
ALL of these things make a HUGE difference in what a tractor can and cannot do.
   / hp requirements for disking #18
Very good point, a 28" conical blade in the 300 to 400lb/blade on an offset disk is a load in itself.
Also most seem to think a tiller is alot slower than a disk without considering that most of the people here have very small tractors with less tractive force than a good pickup.
   / hp requirements for disking #20
Steve,
I'm confused. I've always tried to run disks around 7 mph. Admittedly I've never run anything in the 40 foot wide class (never ran any bigger than 12'.) I've never seen the tractor/tiller combination that could run that fast. What tiller/tractor is as fast as a disc?
Joe
2013 Freightliner M2 106 16ft Stakebody Flatbed Truck with Liftgate (A55852)
2013 Freightliner...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2019 FREIGHTLINER...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
2020 DRAGON ESP...
2012 TOP HAT TRAILER GOOSENECK FLATBED TRAILER (A58214)
2012 TOP HAT...
VOLVO A40D OFF ROAD DUMP TRUCK (A60429)
VOLVO A40D OFF...
