can you guess what these things are??
   / can you guess what these things are?? #1
allen in texas
Levelland, TX
Kubota Grand L 5740, loaded R1's w/640 lbs cast weight, 854 loader
My brother made them for me at his machine shop.
2 1/4 inches long
3/4 inch hole through the middle
2 inch large OD
1 1/4 small OD
I'll tell ya later after a few guesses
   / can you guess what these things are?? #2
At first I thought they look like an adapter to go from cat 1 3PH to cat 2 for use with a quich hitch(hence the shoulders), but a cat 2 is only 1 1/8". So I have no clue.
I assume it is tractor related??
   / can you guess what these things are?? #3
Roller guides for sprayer hose?
   / can you guess what these things are?? #4
Something to keep your brother busy.
   / can you guess what these things are?? #5
Spools for an ABU Garcia baitcasing reel??? ;)
   / can you guess what these things are?? #7
All you guys are way off... These are obviously custom spools for his sewing machine. :laughing:
   / can you guess what these things are?? #8
Picnic table for mice with a hole in the middle for an umbrella your wife is now making out of your old railroad socks?
   / can you guess what these things are?? #9
Big thumbtacks after you put the pointy metal shafts inside.......to keep John Deere pictures up on the barn walls......
   / can you guess what these things are?? #10
I'll need to buy some vowels;)..does it have something to do w/tractor or attachment?
Maxi Grapple (A50775)
Galvanized steel Fence (A53424)
Galvanized steel...
2239 (A51244)
2239 (A51244)
Sheets of 12' Tin (A53316)
Sheets of 12' Tin...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A55302)
Greenworks...
