can you guess what these things are??
   / can you guess what these things are?? #1
allen in texas
Platinum Member
Levelland, TX
Kubota Grand L 5740, loaded R1's w/640 lbs cast weight, 854 loader
My brother made them for me at his machine shop.
2 1/4 inches long
3/4 inch hole through the middle
2 inch large OD
1 1/4 small OD
I'll tell ya later after a few guesses
   / can you guess what these things are?? #2
At first I thought they look like an adapter to go from cat 1 3PH to cat 2 for use with a quich hitch(hence the shoulders), but a cat 2 is only 1 1/8". So I have no clue.
I assume it is tractor related??
   / can you guess what these things are?? #3
Roller guides for sprayer hose?
   / can you guess what these things are?? #4
Something to keep your brother busy.
   / can you guess what these things are?? #5
Spools for an ABU Garcia baitcasing reel??? ;)
   / can you guess what these things are?? #7
All you guys are way off... These are obviously custom spools for his sewing machine. :laughing:
   / can you guess what these things are?? #8
Picnic table for mice with a hole in the middle for an umbrella your wife is now making out of your old railroad socks?
   / can you guess what these things are?? #9
Big thumbtacks after you put the pointy metal shafts inside.......to keep John Deere pictures up on the barn walls......
   / can you guess what these things are?? #10
I'll need to buy some vowels;)..does it have something to do w/tractor or attachment?
2019 Ford F-350 4x4 Crew Cab Auto Crane EHC-4 4,000lb 2 Ton Mechanics Crane Service Truck (A53422)
2019 Ford F-350...
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A56129)
2020 FREIGHTLINER...
2006 JLG 2030ES 20ft Electric Scissor Lift (A55851)
2006 JLG 2030ES...
John Deere 4400 Compact Tractor (RUNS) (A50775)
John Deere 4400...
Cast Iron Mailbox (A55758)
Cast Iron Mailbox...
