Remotes Spools - Power Beyond vs. Outlet?
/ Remotes Spools - Power Beyond vs. Outlet? #1
DiezNutz
Central MD
Kubota B3030-HSD-F
Hey Guys,
In the context of open-center Kubota implement loops, at least, I'm struggling to understand the subtle difference between
- PB port on a stack with PB
vs.
- Outlet port on a stack with NO PB (or PB plugged)
In each scenario, either port receives full flow of the Inlet port when all spools are neutral, right?
Aren't they both "cut off" from Inlet flow if one of the spools is diverting flow to a work port? (rendering the PB useless, really?)
I know the Outlet also gets "waste oil" from (e.g.,) the non-working port of a DA cylinder, but otherwise I don't see alot of difference.
I'm thinking no matter where I put the stack in the system, I don't really need a PB port... either just run the Outlet to my next set of valves or to the tank return.
Thanks in advance,
-DN
/ Remotes Spools - Power Beyond vs. Outlet? #2
If you're going to have any valve downstream of this valve it needs to be power beyond. The "out" on a regular valve is not designed to see pressure and should only go to the reservoir.
Kim
/ Remotes Spools - Power Beyond vs. Outlet? #3
Hey Guys,
vs.
Not quite. There's no flow through the outlet port when in neutral, only the PB. When not in neutral there is flow through the outlet, but not the PB.
The power beyond is cut off. That's why you can only run one implement at a time. The outlet has to be open, otherwise where would the waste oil go?
The oil that comes from an implement is displaced oil, it's only under enough pressure to be forced out of the cylinder.
I'd try to stop thinking that, it won't work.
/ Remotes Spools - Power Beyond vs. Outlet? #4
Thanks in advance,
-DN
Do you think Manufacturers just make these PB valves for no reason at all....Think Again.....this topic has been beaten to death over and over for lots of good reasons!!!!!
You are only saying this cuz you don't understand hydraulic valve operation and design.....connecting valves in series without utilizing PB to drain relief valves to tank exposes unwanted overpressures in upstream components if multiple valves are being used at the same time.....possibly resulting in damaged hydraulic components and/or personal injury......:thumbdown:
Just do a search on "Power Beyond" to see for yourself......DON'T just connect them together w/o PB:)
/ Remotes Spools - Power Beyond vs. Outlet? #5
Not quite. There is some kind of pressure reducing device in the valve, not sure if it's an orifice or what, but it causes the outlet pressure to drop to whatever the suction side of the system can handle.
What???????????:confused2:
Kim
Thanks Kim, this is a good point that hadn't occurred to me. I guess the Outlet-only type of valve assumes it's routing directly back to the tank.
I'm with you, but if you go back and read my original question, I'm talking about the subtle difference between 2 different valve setups... the 2nd kind has no PB port, therefore everything has to come out the Outlet port one way or another. Everything else you said (re: valve setup #1) I know/agree with.
Hmmm, well first of all, welcome to TBN. You're on the fast track. :thumbsup:
Second, you try searching exactly for "power beyond" and then report back here what you come up with. Go on, try it. Or maybe it's that there's some advanced search capability that I don't know about, but the Search feature has always left alot to be desired IMO.
Third, I asked a specific question that I hadn't really seen asked, in the way that I asked it, in all the threads that I have read. I understand more about these valves than you're giving me credit for. But thanks for trying to help. ;)
Anyway, I've got to think about this some more... because my existing return line doesn't really go directly to the tank, it goes to the PCV and 3PH cylinder. So no matter what, I *potentially* could have downstream pressure... so assuming I buy a stack with PB port and connect the PB port back into this "return", that leaves me with exactly where on the B3030 am I going to route this Outlet port to, to get directly back to the tank. (?)
/ Remotes Spools - Power Beyond vs. Outlet? #7
I am having a hard time following here. If you are adding a set of valves, you need at least one set with PB. PB feeds to the added set(or old set). New valve, or old valve with out PB, yes has a outlet refered as T for tank or a return line. Or are you talking about an added valve that goes on a stack valve set up????
Wdchyd, does know what he is talking about. Read some of his posts in hydraulics, he has worked on a few systems.
The valves with out PB can not feed to another set for one reason is your pressure relief valve will not be able to relieve it self. At some point something might have to give if you are using valves that is being fed down stream.
The first one... adding a separate set of valves (for rear remotes).
I'm with you, but isn't it true that that's *only* a problem if you tried to use two different sets of valves simultaneously? Again, if my whole system is open-center, there isn't any pressure downstream if no downstream valves are being used - right?
Not trying to argue with anyone, it's just that there's lots of posts where everybody says "you have to use PB with separate outlet to tank", but nobody really completely explains why, and that's what I'm trying to understand. You guys are helping, thank you.
So what I've gathered from you and Kim is that even though such things as outlet-only open-center valve stacks exist, they're really only intended to be used by themselves or at the end of a run, where they can return directly to the tank with no back pressure. Right?
Maybe this will also help explain where I'm coming from/my confusion. My backhoe (set up by dealer) appears to be fed from the PB port of my loader valve. But there's only one line returning from it. I'm pretty sure that makes it an outlet-only. The BH manual says it should return to tank, so we can assume it is not designed to handle back pressure. BUT - It does not return to the tank, it returns to the hydraulic block, which as I pointed out earlier, goes to the PCV/3PH.
So naturally, my mind wonders "well if it's good enough for the BH, why isn't it good enough for a set of remotes?" I think the answer is, the dealer made the assumption (a reasonable one) that I would not be trying to use the BH and 3PH simultaneously, therefore the BH outlet will not see any downstream pressure (since it free-flows thru PCV).
I think the same logic could apply to remotes, only problem is I would definitely be using downstream PCV, and therein lies the problem.
Does that about sum it up?
I think I answered my own question about the return to tank, which is to tee into the loader valve return. Hence the "tee" everyone talks about (but seldom explains). I know, every tractor is different.
/ Remotes Spools - Power Beyond vs. Outlet? #9
See if this clears anything up for you:
On my B2910, my rear remotes are plumbed into the rear auxiliary hydraulic block (this is not the aux hydraulic source for the FEL, which is further forward)
The hydraulic source comes out of that rear hydraulic block via a line to the valve (3 spool Prince SV) - and then the power beyond off the valve runs back to rear aux hydraulic block - to operate the 3PH and position control valve.
The return line off the rear remote valve is plumbed (with a tee) into the same return that the FEL uses ..... (under the seat, near the cruise control linkage)
/ Remotes Spools - Power Beyond vs. Outlet? #10
If you use down stream valves is the problem with the upstream valve....No pressure if no valves are actuated.
Correct.
I do not know what your set up is but, I bet you can not use 3ph when BH is on. Your system gets pressure relief back to valve with PB.
/ Remotes Spools - Power Beyond vs. Outlet? #11
Yes, thanks for the info. :) Our tractors are pretty similar models. Any advantage to plumbing remotes from the rear block (mine's capped) as opposed to taking advantage of the existing lines to/from the front block? Based on the hydraulic system diagram in the WSM, the only different between the front & rear blocks is that the tractor's relief valve is between them. This means the front block has no relief, but the loader valve has its own. Does the loader valve's relief also protect from whatever's attached downstream from its PB port, or is it only for the valve itself? (LA403 manual is useless when it comes to these details)
Kinda scratching my head as to why the dealer plumbed the BH lines all the way from the front instead of using the rear block... can't imagine they like running long hoses just for the extra challenge. Maybe it was to save on the extra connections at the rear block... or maybe it was to make sure the BH wasn't hampered by the tractor's relief valve, since the BH relief setting is a little bit higher... or maybe because they wanted to leave it available for future add-ons (like factory remotes).
OK thanks, that's what I thought.
Correct.
Again, thanks for confirming. :)
I would bet you're right that I couldn't do both simultaneously. But I never tried to move 3PH when BH is mounted, wouldn't make sense to since the arms hit the frame - which is what I think the dealer counted on. And based on what I've learned here, I'd be a little concerned to even try that now.
I often use Google to "search only this site" Click here: site:www.tractorbynet.com power beyond - Google Search
Wow, thanks neighbor! :thumbsup: I never even thought to try that here - doh! :ashamed: Much better than trying to fool this search engine into doing the one simple thing it's programmed to do, which is return 10X as much stuff as what you really want.
Go figure, among the first few hits using your search method was this one, which addressed some of my questions/concerns:
http://www.tractorbynet.com/forums/hydraulics/116052-what-does-power-beyond-really.html
/ Remotes Spools - Power Beyond vs. Outlet? #15
DiezNutz,
I have a Kubota L-35 that came with the Factory FEL and BH. When I take the BH off I have to do 2 things.
1. I have to connect the feed and return line for the BH to each other, and
2. I have a lever/valve that I push or pull, depending on what I'm wanting to operate, BH or 3PH.
Does your tractor NOT require you to switch any valving around for proper 3PH function?
I've wanted to add rear remotes to my tractor but am not sure how this would be done with its present set up.
DiezNutz,
1. I have to connect the feed and return line for the BH to each other, and Yes, that's right.
2. I have a lever/valve that I push or pull, depending on what I'm wanting to operate, BH or 3PH. You lost me at #2. :confused:
The only thing I have to do is #1 (complete the circuit) when I take the BH out of the loop. I.e.,
Pump -> FEL -> BH -> PCV/3PH becomes
Pump -> FEL -> PCV/3PH
I'm not sure either, without understanding what you mean by #2.
At this point I'm leaning toward plumbing my remotes off the rear block even though I already have existing lines I could take advantage of. Mainly because I don't want the remotes ahead of the BH. I still have a potential issue with the BH upstream of anything I add (let alone the 3PH), but I don't anticipate a scenario where I need to use remotes with BH attached, just like I don't use the 3PH when BH is attached.
[Only maybe if I converted my thumb to hydraulic, but I can't really justify the hassle vs. reward... it's pretty painless to work with the way it is. Plus I would only have to worry if I were loading the thumb with the remote, if I'm merely positioning it unloaded, should still be OK; the load checks in the remote spool would keep it in place without back pressuring the upstream BH outlet.]
/ Remotes Spools - Power Beyond vs. Outlet? #17
You're quite welcome :D
Yup - that's why I brought it up.
Although I haven't scoped out the 3030 up close and personal, I imagined that they might be.
Yeah - a couple, perhaps somewhat minor:
1. Somewhat shorter lines (depending on where exactly you are mounting the remote valve), and maybe a little cleaner routing/install (hard lines to the valve would be really nice ....)
2. As was pointed out to me by MadReferee (May he rest in piece) when I was doing my remote install, on the B2910 the fluid channel (that goes to the 3PH) in the stock rear cover plate is more restrictive than the fluid channel in the rear aux hydraulic block.
IOW, the aux hydraulic block has a wider, more open channel, capable of more flow to the 3PH. Not sure how it compares in this regard to the front hydraulic block for the FEL.
Not sure.
Kinda scratching my head as to why the dealer plumbed the BH lines all the way from the front instead of using the rear block ...
On the B2910, the rear auxiliary hydraulic block is not supplied with the tractor - it's an optional part (about $100, IIRC) - the stock cover plate (for the aux hydraulics) is included with the tractor (at no extra charge :laughing:) .... but of course there aren't any taps on it ...... it's just a cover plate.
Yup .... ;)
Maybe it was to save on the extra connections at the rear block ... or maybe it was to make sure the BH wasn't hampered by the tractor's relief valve, since the BH relief setting is a little bit higher... or maybe because they wanted to leave it available for future add-ons (like factory remotes).
Perhaps any of the above .... might also have been a cost or availability issue as well (dealer didn't have it in stock, or it wasn't available at the time, etc.)
/ Remotes Spools - Power Beyond vs. Outlet? #18
I hope this picture helps.
Just below the green leaf is the placard for the Directional Valve. I push it in when I'm using the BH and pull it out for 3PH use. To the right, and a little lower is one of the BH lines.
If I have remotes, I would think that I'd use this attach point and its corresponding line to power them.
Am I WAY off base with my thinking????
Thanks
Hmm... maybe that's to provide/compensate for additional flow to whatever circuit you might attach to the aux block (?) My guess is that the front & rear blocks are very similar or that the front block would actually have the greater flow (e.g., for the FEL). If that were true, maybe that's yet another reason to plumb the BH off the FEL.
Same deal here.
I suspect you're right. All things considered, several extra feet of hose length was likely the cheapest/simplest option.
It's not obvious to me how that valve is connected, unless... are *both* QDs on your tractor, or is one of them on the BH? If it's the latter, then isn't there a hose from the tractor that you must plug back into the QD shown in the pic?
Can you see any details of how this valve is plumbed? Maybe someone else with your model tractor could weigh in.
Nice leaf. Was that strategically placed over the lever as an attempt at modesty? :D
SCAN TO RECEIVE TEXT UPDATES (A65053)
SCAN TO RECEIVE...
2025 32in. Mini Excavator Bucket Attachment (A64553)
2025 32in. Mini...
2023 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A64553)
2023 ASV RT-25...
(4) 25' Texas Built Stand Alone Livestock Panels (A66408)
(4) 25' Texas...
2004 International 4300 ASM Altec AM855 55ft. Bucket Truck (A64194)
2004 International...
2020 CATERPILLER 326 EXCAVATOR (A65053)
2020 CATERPILLER...
