1520 water pump replacement issue?
   / 1520 water pump replacement issue? #1
monteagle auction
ford 1520 with 1780 loader
changing water pump on 1520 Ford, and the replacement pump is off by a bunch as far as the cowling for the radiator, and there is a huge batch of slack in the v-belt. The footprint, however, is correct, the bolt holes are correct, etc. Is there a prescribed workaround other than ditching the cowling and getting a shorter belt? Thought I was losing my mind when the slack wouldn't take up with the alternator.
   / 1520 water pump replacement issue? #2
Any pics? If the water pump pulley and alternator pulley are lining up fine then I'd get a shorter belt. What has changed? do yo have smaller dia pulley for the new pump? is the pump body smaller but has the same foot print?
JC,
   / 1520 water pump replacement issue? #3
The cowling is part of the design of the cooling system - should be in place. Can you shim the fan in or out to make it work, maybe using part of the old pump or something sturdy? Stretching...
Jim
   / 1520 water pump replacement issue? #4
My guess is you have the incorrect pump. make sure you have the correct "1520" pump part as there may/are two model 1520's. One is pre 1999 and other is post 2000.
   / 1520 water pump replacement issue? #5
Ditto. 1520 and T1520. Different animals, but it is quite likely that the water pumps bolt up the same.
John Deere 922 Platform (A50514)
John Deere 922...
more info coming soon! (A50323)
more info coming...
2022 CASE TV370B SKID STEER (A51242)
2022 CASE TV370B...
2004 Honda Pilot SUV (A50324)
2004 Honda Pilot...
Excavator Mulching Head (A50774)
Excavator Mulching...
22ft Progressive Finish Mower (A52128)
22ft Progressive...
