1520 water pump replacement issue?
   / 1520 water pump replacement issue? #1
monteagle auction
ford 1520 with 1780 loader
changing water pump on 1520 Ford, and the replacement pump is off by a bunch as far as the cowling for the radiator, and there is a huge batch of slack in the v-belt. The footprint, however, is correct, the bolt holes are correct, etc. Is there a prescribed workaround other than ditching the cowling and getting a shorter belt? Thought I was losing my mind when the slack wouldn't take up with the alternator.
   / 1520 water pump replacement issue? #2
Any pics? If the water pump pulley and alternator pulley are lining up fine then I'd get a shorter belt. What has changed? do yo have smaller dia pulley for the new pump? is the pump body smaller but has the same foot print?
JC,
   / 1520 water pump replacement issue? #3
The cowling is part of the design of the cooling system - should be in place. Can you shim the fan in or out to make it work, maybe using part of the old pump or something sturdy? Stretching...
Jim
   / 1520 water pump replacement issue? #4
My guess is you have the incorrect pump. make sure you have the correct "1520" pump part as there may/are two model 1520's. One is pre 1999 and other is post 2000.
   / 1520 water pump replacement issue? #5
Ditto. 1520 and T1520. Different animals, but it is quite likely that the water pumps bolt up the same.
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
2003 - 1890/1910 Air Seeder and Air Cart (A51039)
2003 - 1890/1910...
John Deere 693 Corn Head (A50514)
John Deere 693...
2004 CATERPILLAR 963C CRAWLER LOADER (A51242)
2004 CATERPILLAR...
E-Z Trail 680 Head Cart (A50514)
E-Z Trail 680 Head...
2020 CASE CX37C EXCAVATOR (A51242)
2020 CASE CX37C...
