All my door sensors are set up such that the contacts are closed when the door is closed. While I'd call this NC, a few extra words can avoid confusion: "I want it so that when the door is closed the switch contacts are closed."
Three wins there:
1) If the "bad guys" cut the wires, it looks the same as a door entry.
2) If the wiring fails, you know right away because it looks like the door was left open. If the switch is wired so that it's open when the door is closed and then you have wiring probelms, you don't know you're in trouble until you open the door and notice something didn't work right.
2) Usually, one wire is ground and the other is the input to the alarm or automation system. So when the contacts are closed, the input is at ground vs. just floating out there. So things like near lightning strikes, near radio signals (from hand held radios) don't affect stuff. There is a YMMV factor on this one and since the word "lightning" is in there I'm wide open for a lot of flack.
There is also a technique that uses what is called an End of Line (EOL) resistor. This would put a resistor (usually about 2.2K) across (in parallel with) the switch (which is at the end of the line). The security system then has a 2.2K pull-up resistor to +5 at the unit. So if the switch is open, the unit sees 2.5 volts. If the switch is closed, it sees ground. If the wire is cut, you see 5V at the input. It's a great system (the stuff I do supports this feature). With a simple switch and just two wires, you can tell three states: open, closed, bad/cut wires. The problem is you've got to get the resistor installed at the end of the line at the switch. Not too hard to do, but it has confused a few installers. As a side comment, I solder the wires at the wire-switch interface. A little tape (Scotch 33+ or 88) and then heat shrink. I don't want plastic wire nuts buried in the wall where I can't get to them. Now imagine that with a little axial resistor in there too :confused2:.
A seconds problem: I can't tell you how many commercial fire alarms I've seen that the EOL resistor at the panel. Of course, it does no good there. The installer was either lazy or stupid. And the poor owner has no idea.
A third problem: The value of the EOL resistor, along with the pull up voltage, follows no standards. So you have to decide what system you are using and then you are sort of locked into it short of tearing your door casings apart.
The key concept here is that you are aware of this approach. You can see where in a commercial setting, systems that can distinguish between wiring problems and sensor activation is a win. In a home setting, particularly with doors, the value is less clear. This technique can be used on any contact closure device such as smoke and motion detectors. But in those cases, you have access to the device and wiring with little difficultly.
As for a good home automation system, if you can't wait about 2 years for mine to be done, some units to look at are JDS Stargate and the HAI systems. You can google them. A good security system (and cheaper too) with some more advanced systems is made by Elk Products. You could start with that and then add the automation system later (like in two years....). I suspect this is a "post fog" matter, and if so we can talk some night when you're all nestled into you wonderful new house :thumbsup:.
Pete
