Cleaning Fuel Filters
/ Cleaning Fuel Filters #1
TripleR
Super Star Member
Missouri
Kubota M8540HDC, L5740HSTC, BX2200, BX2660, John Deere 425&1025R, Case, Massey Ferguson, Ford
My Operators Manual say to use kerosene to clean the fuel filter on my Grand L. Anyone use anything else and if so what. Thanks
/ Cleaning Fuel Filters #2
I use WD40 for almost all cleaning jobs.
/ Cleaning Fuel Filters #3
My L2800 manual says the same,but rather purchase new filter for peace of mine.
/ Cleaning Fuel Filters #4
Any L-series Kubota that I have seen uses an inexpensive paper cartridge for the fuel filter. Probably still under $10 and should really be tossed rather than cleaned. In an emergency, wash it out with kero, WD-40, or even diesel fuel.
/ Cleaning Fuel Filters #5
For the cost of a new filter it is just insane to try and clean a fuel filter. It is impossible to not contaminate the whole filter. Nothing more expensive than a fuel system to repair.
/ Cleaning Fuel Filters #6
I agree here...
I bought a new filter.. and I have a spare one for emergencies...
If it takes me 10 min to clean it and 10 min to clean myself up..
and a few more to clean up the area where I was making my mess... and then the time to get rid of the Kro or whatever I used to clean it...
Well $10 is cheaper..
3 min to replace it..
of course it is $10 PLUS the O rings that you should replace almost everytime it comes off..
J
/ Cleaning Fuel Filters #7
I remember these discussions from a few years back, and IIRC most TBN'ers chose to replace (myself included).
It's actually kind of surprising that Kubota still promotes the idea of cleaning vs. replacement, seems like kind of a liability. The other concern with cleaning is inadvertantly contaminating the inside of the filter in the process.
Thanks for all of the replies, I was curious why Kubota recommended cleaning the fuel filter, but shouldn't be since they also state to wash the air filter which I refuse to do. I will be replacing it.
/ Cleaning Fuel Filters #9
Just guessing here, but these same Kubota engines go into equipment used all around the world, including some places where parts replacement may not be quite as convenient as it is here in the USA, and equipment may not get pampered quite as much either.
/ Cleaning Fuel Filters #10
Seems to me that cleaning them would open larger pores in the filter...allowing larger size contaminates to get through the filter.
Same holds true for blowing out your air filters with the air compressor. I still use the compressor to clean my air filters, anyways though....
/ Cleaning Fuel Filters #11
Cleaning & reusing a fuel filter is ludicrous!
/ Cleaning Fuel Filters #13
Just wish they would say so in their manuals.
The manuals now (for over 2 years on most) say hydraulic fluids don't need changed at the first 50 hours. Who listens to manuals?:)
Well, I actually try to, but yes there are times I just can't do it either.
I didn't replace my transmission fluid at 50 hours on my BX. The Operators Manual on my 2010 M8540 says to change all fluids at 50 hours.
/ Cleaning Fuel Filters #15
And the hydraulic oil was the most expensive part of the 50 Hour service when we did our M8540 a couple of months ago. But cheap in the long run and piece of mind!
Man ain't that the truth. Due to hoses rupturing and FEL problems with our Case this past year, we went through four complete changes.
Changing fluids seems to be a pretty straight forward operation on the M8540 and after the 50 hour won't be needed for a while; still studying my Operators Manual.
/ Cleaning Fuel Filters #17
Like the others, I replace instead of clean the filter(s)...Have always wondered, if you had 2 of the exact same make/mod tractors and did things "by the book" with one, and "by the common sense" with the other, after 2,000 hours on each, what the wear status would be engine wise and other friction developing areas.
Don
/ Cleaning Fuel Filters #18
Maybe they are making a distinction between fuel filter and fuel filter element
I found that out when going to order the fuel filter housing that it was called the "fuel filter" and it did not come with the "element".
But then, maybe not. :)
/ Cleaning Fuel Filters #19
My grandpa just blows it out with the air compressor.:thumbsup:
HYD OIL, OIL & USED OIL TANKS (A60429)
HYD OIL, OIL &...
2014 Nissan Altima Sedan (A59231)
2014 Nissan Altima...
TPL MECHANICS BODY LUBE SKID (A60430)
TPL MECHANICS BODY...
2019 TAKEUCHI TL10V2 SKID STEER (A60429)
2019 TAKEUCHI...
2018 CATERPILLAR 12M3 MOTORGRADER (A52709)
2018 CATERPILLAR...
2016 John Deer 5075E (A60462)
2016 John Deer...
