At Home In The Woods
   / At Home In The Woods #1,621
FYI, I checked our door sensors and they appear to be closed when the door is closed. Not sure if they call that NC or not in this case (i.e. what is "normal" in Normally closed? When the magnet is in contact or when nothing is in contact?)
-Dave
Normal, as in NO/NC, is the condition the switch is in when it's sitting on your desk not even installed yet. Or it is installed but not actuated. So if you want the switch to be closed when the door is closed, then you need a NO switch. Closing the door actuates the switch thereby closing it.
Hope this makes sense.
A little more brick was put on the back of the house today. They apparrently got stopped by rain. The new brick on the house is covered with plastic. Here's the brick on the front of the garage without the scaffolding in the way of the view.
attachment.php
After I finished the pipe and my wife finished prepping the brick for the forecasted rain, we picked some wild blackberries as the sun went down. I might even get a cobbler out of the deal!
Here's part of the results of picking the berries Friday - shortcake covered with strawberries and blackberries, vanilla ice cream and whipped cream.
attachment.php
The wife is cooking a blackberry cobbler tonight.
   / At Home In The Woods #1,623
Agree, NO/NC is normally defined in the "unenergized" or "natural" state.
   / At Home In The Woods #1,624
Summary: Wire each door on it's own with a home run to the alarm panel, and put the 1K EOL resistor where you connect the wire to the magnetic sensor. The doors per zone can be figured out later.
Pete
...or changed if you decide you want a different configuration.
   / At Home In The Woods #1,625
attachment.php
Wow, that pretty young lady really has you spoiled.:D
   / At Home In The Woods #1,626
Pete,
It may not all be the installers fault. My 15 year old panel at the farm called out in the owners manual for the resistors to be in the panel. This might be for a different purpose, but I remember that either the NO or NC configuration called for resisters in the panel. My panel did both and didn't care as long as the resistor was put in for the correct configuration.
buckeye and Danno are right in their posts. And the "Hope this makes sense" is right on the money too. All to confusing. That's why I just like to say what I want to have when the door is shut, and I'm sorry that I was not clear and that this doesn't help someone buy a magnetic plunger reed switch.
Cyril, I've been chewing on your post all day. If you had NC swtiches (which would have open contacts when the door is shut) and if you had a system where each zone had a pull up resistor on it, and if the controller did not have programable thresholds (most don't), then putting the EOL on the controller makes it work. You see 2.5 Volts when the door is shut, and ground when the door is open. You can not tell when the wire has been cut. This is why I like the Normally Open ( NO ) switch which has the contacts closed when the door is closed because you can tell when the wire is cut (if your controller supports this). I had one house where the finish carpenter put a nail right through the plunger. It was nice to only have that door bad, and to be able to diagnose it easily.
On my house, I did not use EOL resistors on the doors. The NO switches were just fine, and wiring problems just look like the door is open. Each door is a home run. But the EOL's are fine, and my decision might just be another case of the cobblers children have no shoes.
So on some systems, you need to set up the system with the knowledge of the polarity of each zone (i.e. is it a NO or NC) and the voltages are fixed. Why is it when there are only two possibilities, people manage to make things the most complex :confused2:?
I think this could lead to installers always putting the EOL at the controller because it always works as far as sensing where the door is. And if they blow off the cut wire functionality, life is simple. I have seen the EOL on systems with NO switches at the controller. One industrial site in particular had never ending alarm problems they could never diagnose because they could not tell if the wires were intact. Walking and flying rodent infestation didn't help either. They ended up re-wireing the entire plant (and got a new alarm contractor who did it right).
Realizing I'm long winded, let me try to summarize all this for people who want to make stuff work. IMHO, I would:
1) Use Normally Open (abbreviated NO) door plungers so that when the door was shut the contacts are shorted.
2) Put the EOL resistor at the device, realizing you may need to select what system you have so you know the correct value for the resistor.
3) Solder, tape, and heat shrink because you're burring this thing forever.
4) Home run all doors in your prewiring. You can determine zones later and it's really not that much more work. It will also make it much easier to diagnose wiring problems should they show up later.
5) I'd use an 18 gauge stranded wire with an overall jacket. It's a little more money than the 22 or 24 gauge stuff you can get, but it will stand up to the riggers of construction. You can step on it, hit it with a hammer and pull it and it is still good.
Pete
Edit: Yeah, that cobbler looker yummy !
   / At Home In The Woods #1,627
It's been 15+ years since I installed the panel and the resistors at the panel are the only things which stick in my mind. I'm sure you are correct about the reason for them.
One of these days I'll rebuild the system, but I haven't seen what I want on the market yet. Maybe I'll Email you or start my own thread for ideas somewhere down the road.:thumbsup:
Thanks for the clarification. EEPete's description of "the switch is closed when the door is closed" helps avoid confusion when talking to the installer. However, after looking online, the switches never describe themselves like that. So now I understand that I will be getting normally open (NO) contact switches (i.e. closed when the doors are closed).
Thanks,
Obed
   / At Home In The Woods #1,629
If you home run's them you can group them at the panel or ungroup them later if you want changes.
The only way to go unless you end up with a wire distance problem.
Today the security guy ran security wiring for the following devices:
2 key pads - Cat 6 - master BR and door to the garage
3 motion detectors - one in main floor hallway and 2 in the unfinshed basement
9 doors
2 glass break detectors - main floor
1 phone wire from place where phone enters to house
All wire runs are home runs to the equipment closet. No devices were installed; only wiring was run.
Obed
2018 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2018 Ford F-550...
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A56435)
2023 Top Air ATV...
INTERNATIONAL FLAT BED TRUCK (A52707)
INTERNATIONAL FLAT...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
2018 John Deere TX (A53317)
2018 John Deere TX...
Club Car Carryall 2 Electric Utility Cart (A55851)
Club Car Carryall...
