##Damaged my 3320 today, advice please PICS##
   / ##Damaged my 3320 today, advice please PICS## #71
Just make sure your implement drive shaft doesn't bottom out unless you're using a QH or Pat's (and haven't modified the drive shafts to suit).
I have read (probably here on TBN) PTO extenders can result in premature wear on the tractor's stub shaft bearings. I have no idea if that's true and I still use my extender when hooking up my chipper (Woods chippers come with very short drive shafts).
I use a Quick-Hitch, which is why I got the 4" PTO extender; but thanks for the warning.
I think I would weld it too, even if it was just to save as a spare.
By the way, you can MIG it also.
For those of you who don't know, there are four types of cast iron:
Grey, white, maleable and nodular. White is not weldable but the rest are. I use ER70S-6 from Radnor. Which i also use for most welding apps even mild steel. It works well on oily, dirty or rusty metal too.
Rob
My first spool of MIG wire was Radnor as I got it from the Airgas dealer I bought my Miller from. When it ran out, I got some Lincoln wire, and it makes for a much better weld.
Radnor Wire.
Lincoln wire.
   / ##Damaged my 3320 today, advice please PICS## #72
Rob,
I would doubt that the hook is cast.... most are forged.
That's a good point, possibly yes, but it still has very much the same composition and weldability of a cast piece.
Rob
   / ##Damaged my 3320 today, advice please PICS## #73
Radnor Wire.
Lincoln wire.
That looks like a different wire composition, what are the numbers? I have Lincoln and Radnor wire but not the same direct cross reference. They look like two different heat ranges.
Is that stainless?
Rob
   / ##Damaged my 3320 today, advice please PICS## #74
Rob:
The camera's flash is giving the illusion of stainless. The Lincoln wire I got at Home Depot, and right off-hand i don't recall which wire I bought; but I do remember that according to Lincoln, it was a good general purpose wire.
As for the Radnor wire, I think I saved the plastic spool with the model number on it.
If you'd like, I can try and track both down for you.
   / ##Damaged my 3320 today, advice please PICS## #75
Rob:
Thanks Mjncad but that's OK. I would be curious about the disignation number on the Lincoln wire though, it should be on the spool.
   / ##Damaged my 3320 today, advice please PICS## #76
Forged parts can and often do have what looks like a mold parting line. The extra metal that is squeezed out between the dies in the forging process is often trimmed and/or ground off and looks like a mold parting line.
Yes, that's true. I looked at a bunch of forged hooks, etc that I have,
all marked "forged". Some have parting seams, some of which seem to
be ground off. I suspect that *all* hooks of this type are forged, not
cast, as you state. I also have some cheapo Chinese slip hooks, not
marked, with no parting seams, and I have bent several of them when I
used them as cable chokers.
   / ##Damaged my 3320 today, advice please PICS## #77
I'd say you guys are probably correct.
Rob
I've been threadjacked! ;)
   / ##Damaged my 3320 today, advice please PICS## #80
Sorry, bottom line is you have a choice to weld or buy new. The point is that cast iron can be welded relatively easily which makes welding is a viable option.
Rob
2008 Ford F-350 4x4 Pickup Truck (A50323)
2008 Ford F-350...
2014 Chevrolet Cruze Sedan (A50324)
2014 Chevrolet...
2012 Ford E-150 Passenger Van (A51692)
2012 Ford E-150...
2015 JLG 2632ES 26ft Electric Scissor Lift (A50322)
2015 JLG 2632ES...
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
EZ-GO Electric Golf Cart (A50121)
EZ-GO Electric...
