mjncad
Super Member
Just make sure your implement drive shaft doesn't bottom out unless you're using a QH or Pat's (and haven't modified the drive shafts to suit).
I have read (probably here on TBN) PTO extenders can result in premature wear on the tractor's stub shaft bearings. I have no idea if that's true and I still use my extender when hooking up my chipper (Woods chippers come with very short drive shafts).
I use a Quick-Hitch, which is why I got the 4" PTO extender; but thanks for the warning.
I think I would weld it too, even if it was just to save as a spare.
By the way, you can MIG it also.
For those of you who don't know, there are four types of cast iron:
Grey, white, maleable and nodular. White is not weldable but the rest are. I use ER70S-6 from Radnor. Which i also use for most welding apps even mild steel. It works well on oily, dirty or rusty metal too.
Rob
My first spool of MIG wire was Radnor as I got it from the Airgas dealer I bought my Miller from. When it ran out, I got some Lincoln wire, and it makes for a much better weld.
Radnor Wire.
Lincoln wire.
