##Damaged my 3320 today, advice please PICS##
   / ##Damaged my 3320 today, advice please PICS## #71
Just make sure your implement drive shaft doesn't bottom out unless you're using a QH or Pat's (and haven't modified the drive shafts to suit).
I have read (probably here on TBN) PTO extenders can result in premature wear on the tractor's stub shaft bearings. I have no idea if that's true and I still use my extender when hooking up my chipper (Woods chippers come with very short drive shafts).
I use a Quick-Hitch, which is why I got the 4" PTO extender; but thanks for the warning.
I think I would weld it too, even if it was just to save as a spare.
By the way, you can MIG it also.
For those of you who don't know, there are four types of cast iron:
Grey, white, maleable and nodular. White is not weldable but the rest are. I use ER70S-6 from Radnor. Which i also use for most welding apps even mild steel. It works well on oily, dirty or rusty metal too.
Rob
My first spool of MIG wire was Radnor as I got it from the Airgas dealer I bought my Miller from. When it ran out, I got some Lincoln wire, and it makes for a much better weld.
Radnor Wire.
Lincoln wire.
   / ##Damaged my 3320 today, advice please PICS## #72
Rob,
I would doubt that the hook is cast.... most are forged.
That's a good point, possibly yes, but it still has very much the same composition and weldability of a cast piece.
Rob
   / ##Damaged my 3320 today, advice please PICS## #73
Radnor Wire.
Lincoln wire.
That looks like a different wire composition, what are the numbers? I have Lincoln and Radnor wire but not the same direct cross reference. They look like two different heat ranges.
Is that stainless?
Rob
   / ##Damaged my 3320 today, advice please PICS## #74
Rob:
The camera's flash is giving the illusion of stainless. The Lincoln wire I got at Home Depot, and right off-hand i don't recall which wire I bought; but I do remember that according to Lincoln, it was a good general purpose wire.
As for the Radnor wire, I think I saved the plastic spool with the model number on it.
If you'd like, I can try and track both down for you.
   / ##Damaged my 3320 today, advice please PICS## #75
Rob:
Thanks Mjncad but that's OK. I would be curious about the disignation number on the Lincoln wire though, it should be on the spool.
   / ##Damaged my 3320 today, advice please PICS## #76
Forged parts can and often do have what looks like a mold parting line. The extra metal that is squeezed out between the dies in the forging process is often trimmed and/or ground off and looks like a mold parting line.
Yes, that's true. I looked at a bunch of forged hooks, etc that I have,
all marked "forged". Some have parting seams, some of which seem to
be ground off. I suspect that *all* hooks of this type are forged, not
cast, as you state. I also have some cheapo Chinese slip hooks, not
marked, with no parting seams, and I have bent several of them when I
used them as cable chokers.
   / ##Damaged my 3320 today, advice please PICS## #77
I'd say you guys are probably correct.
Rob
I've been threadjacked! ;)
   / ##Damaged my 3320 today, advice please PICS## #80
Sorry, bottom line is you have a choice to weld or buy new. The point is that cast iron can be welded relatively easily which makes welding is a viable option.
Rob
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A52748)
2020 Massey...
2011 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2011 Ford F-150...
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A52748)
2022 Gravely...
2012 NEW HOLLAND BOOMER 3045 COMPACT TRACTOR WITH 250TL LOADER (TRANSMISSION ISSUES) (A52748)
2012 NEW HOLLAND...
2019 Chevrolet 2500 4x4 Extended Cab Knapheide Service Truck (A50323)
2019 Chevrolet...
2013 Chrysler 200 Sedan (A50324)
2013 Chrysler 200...
