Warranty void by adding hooks on FEL?
/ Warranty void by adding hooks on FEL?
Speaking of taking the loader off and putting back on....
I found a level spot near the driveway so the welder could get to it.
I thought I would practice taking it off and putting it on a couple of times as I had not done this with this tractor yet.
So, I follow the directions, pull the pins, make sure the hoses are free and then move the bucket lever in the up position and back away slowly and walla, off it came....no sweat.
Then I unhooked the hoses....backed away and got off....and covered the couplers with the caps.
Then I thought I would try and put it on.
Ok....I pull forward, I think I am square to the loader.
I hook up the hoses.
I nudge the loader and then move the lever to lower position slowly.
the loader slides forward about 2 feet... :eek: ....I drive up to it and try again...and it slides across the lawn about 3 feet...:eek: ....I try again and again and it slides and slides. :smiley_aafz:
I had to move my pickup in front of the bucket so it would stop sliding.
(I nudged my tire to do this)
Then it went on.
I had not been perfectly square with it though, so I had get off and to shove it a bit to the left in order for the posts to line up, but I got it.
If I did not know better I would have sworn someone was messing with me the way it was sliding and sliding....if I did not have my truck there it would have ended up across the street in the neighbors yard and I coulda used one of his big pine trees to stop it.
:eek:
/ Warranty void by adding hooks on FEL? #42
Jim,
I hope you have backing plates inside the bucket under those hooks. I bolted those type hooks on my first tractor bucket with no reinforcement. I think I must have side loaded them somehow, maybe with a "Y" arrangement connecting one lift point to both hooks. It bent the sheet metal slightly where the bolts go thru. And my bucket wasn't a pretty as yours.
John
John - good advice. In my application (LA724 HD bucket) the holes are drilled through thick material - I'd say about 1/8" and right next to the tube that reinforces the edge. Also, I used large, thick washers under the nut on the opposite side to spread the load, so I'm not worried about deforming the bucket in my case.
... Also, under no circumstances would I ever even consider welding on a bucket attached to any tractor made after the mid 60's. Probably things would go okay, maybe not. If you're willing to risk what could easily be a couple thousand bucks just to make sure no current flows into the tractor electronics, you're a far bigger gambler than I. Your advice on dropping the bucket or taking the loader completely off if need be is spot on. I'll even go so far to say that not doing so is simply foolish.
Dargo - Good point! I have suspected that welding onto anything directly attached to the tractor is probably a bad idea. Now I know it's something to avoid. Besides, I need to try dropping the FEL so I can do it quickly when I need to in the future.
-Jim
/ Warranty void by adding hooks on FEL? #43
Then it went on.
:eek:
Stop pushing, pull up to it, reach out with loader arms tilt down just a little, lift up and tilt back, then lock down
/ Warranty void by adding hooks on FEL? #44
Here's my entry in the bucket hook contest... My dealer didn't bat an eye when he saw these, except to say "nice hooks". The inner three are used for lifting depending on the physical configuration of the load, the outer two are strictly there for keeping bulky things from falling out of the bucket while carrying them around, and are never used for lifting (or pulling on) anything.
I can't reach out with the loader arms because they are on the loader.....which is parked ....separate from my tractor
or am I missing something?
I was not trying to hook up a quick attach bucket....as I have no QA anything
I had taken the whole loader assy off the tractor for welding
/ Warranty void by adding hooks on FEL? #47
I think he means...once you have your hoses connected, pull back (as if you were raising the loader) on the loader joystick (slowly, and the engine should be at a low idle). By pulling back on the stick, the loader masts (those sections that mount to the tractor brackets) will extend up and out toward the tractor. Move the tractor slowly forward and push the loader joystick forward (as if you were lowering the loader). The loader arms will retract and the masts will lower and pivot down toward the mounting brackets on the tractor.
Just take your time and you'll see how it works. It's no big hurry to accomplish this...speed will come later. It might take a time or two to get the tractor aligned to the loader. Just remember to not back away too far if you need to reposition the tractor. Those hoses aren't too long.
If you're moving the loader, your tractor is too close.
thanks roy.
Yeah...only doing it twice, I am sure I did not do it 100% right.
I think I followed those instructions and each time the whole assy slid forward even when I was dead stopped.
But, like I said...I only did it twice and am not 100% sure if I did it right
/ Warranty void by adding hooks on FEL? #49
****, how do you keep the inside of that bucket so clean?
I only have 117 hours on mine and the paint is almost all worn off on the leading edge, I guess I do use my bucket a lot
/ Warranty void by adding hooks on FEL? #50
thanks roy.
Two things come to mind:
You should only be using the loader functions of the joystick, not the bucket, until it's mounted.
You may have your loader hoses connected wrong (bucket might be moving instead of the loader frame members).
I can't see why the loader would be moving with the tractor stationary.
You may have to use the dump function to lock the loader on later though (Deere QA loaders that I'm familar with require the front end of the tractor off the ground to lock the latches...this is done by using the dump function of the bucket). But the loader frame should be mounted on the tractor before this is required.
If you have the tractor's or loader's operator manual, have it with you as you do this...go step by step following the procedure.
/ Warranty void by adding hooks on FEL? #51
I don't know the exact procedure for mounting/dismounting New Holland loaders, but Kubota calls for use of both lift and dump cylinders. If I remember correctly, the lift function takes the load off the pins, the curl "floats" the arms out of the brackets.
Sean
From the Manual:
REMOVING THE LOADER FROM THE TRACTOR:
1 - Locate the tractor and loader on firm level ground.
2 - Lower the bucket to the ground, stop the tractor engine, and set the brakes.
3 - Disconnect the rubber tie down strap that retains the hydraulic hoses to the loader side frame.
4 - Remove the pin and release the latch from each loader frame upright.
5 - Start the tractor engine and release the brakes. Activate the lift control lever to raise the side frame uprights from the mid mounting assembly
6 - Gradually activate the lift control lever. At the same time, back the tractor up slowly, allowing the loader to roll off of the front mounting bracket.
7 - Continue to back the tractor up slowly until the lift cylinders are fully extended and the loader's parking stand is resting on the ground.
8 - Engage the tractor brakes and stop the engine. Activate the control lever to relieve the pressure in both the bucket and lift circuits.
9 - Disconnect the quick couplers and install clean dust covers on all ends. Position the ends of the hoses with the couplers on the loader so they do not contact the ground.
This went almost perfectly.
MOUNTING THE LOADER ON THE TRACTOR:
Reverse the removal procedure to mount the loader on the tractor.
1 - Slowly drive the tractor into the loader until the hoses reach from loader to the tractor. Engage the tractor brakes and turn off the engine.
2 - Check the couplers to make sure they are clean and then connect them by matching the color coded identification rings on the quick couplers.
3 - Restart the tractor engine, release the brakes, and slowly drive the tractor forward until the front mounting bracket tubes, contact the side frame channels.
4 - Gradually activate the lift control lever to retract the lift cylinders and roll the loader onto the front mounting bracket tubes.
(Here is where the whole loader started to slide forward on the ground for me. And as it slid, it appeared to be sliding off of the front mounting tubes and I assumed it might fall to the ground because the support leg was no longer extended straight up and down.)
5 - Continue rolling the loader onto the mounting bracket tubes while easing the tractor ahead.
(Here is where I had to move forward but the loader would slide a bit more and more.)
6 - When the side frame mounting hooks are fully engaged on the front mounting bracket tubes, and the side frame uprights are fully resting on the mid mounting assembly, (This is where I had to get off and physically shove the assy to the left to get both uprights to line up with tubes. I probably was not square to the loader due to chasing it across the lawn.) engage the tractor brakes and shut off the engine.
7 - Latch the rear frame upright clamps by rotating the hinge plate up against the mid mount tube, placing the T-bracket into the slot of the hinge plate while rotating the over-center latch handle towards the rear of the tractor until it is vertical. Insert the pin.
8 - Retain the hoses to the loader side frame with a rubber tie down strap.
9 - Start the engine and activate the control lever. If the loader does not operate as shown on the control decal , switch hoses at the couplers until it matches.
So, I was following the instructions step by step. it shows to inch forward and not stay in place. The sliding started as soon as step 4 and I did not want the loader to fall to the ground on the one end.
/ Warranty void by adding hooks on FEL? #54
From the Manual:
And follow those same steps in reverse order.
/ Warranty void by adding hooks on FEL? #55
Dump the bucket so the cutting edge digs in a little, that will keep it from scooting away from the tractor. Not written, and nothing but experience will teach it. If you are on a concrete surface, you are basically screwed until the bucket contacts something that will hold it stationary. BTDT, dozens of times with multiple customers. And I won't apologize for the moron who wrote the Op manual, or the engineer that signed off on it.
/ Warranty void by adding hooks on FEL? #56
A few differences from mounting the Kubota loader. You essentially drive "into" or "under" the disconnected loader. If you're off a little, the edges of the loader brackets are flanged to guide the loader arms into place. Once the loader arms contact the brackets, the hydraulics lower the arms into place and raise the front of the tractor to allow you to put the pins in place.
A couple of times I've had one arm touch before the other, driving an inch or two further ahead shoves the loader to one side a little bit and lines everything up.
Sean
Also
Thank you to all who offered their ideas and opinions
that is what makes TBN a nice place to visit and learn
/ Warranty void by adding hooks on FEL? #59
...If you are on a concrete surface, you are basically screwed until the bucket contacts something that will hold it stationary...
I park my loader on smooth concrete (garage floor) all the time, never had it slide during removal or installation.
BTW, I see Yooper has a New Holland T1510. Is this a replacement for the TC-30?
/ Warranty void by adding hooks on FEL? #60
I'm the same, Roy. Neither one of us has a New Holland though. I think the difference in the way the loader attaches is why he had that happen.
Sean
Honda utv cart (A56859)
Honda utv cart...
2013 Club Car 4x4 Diesel Utility Cart (A59228)
2013 Club Car 4x4...
LOT LOCATIONS (A59904)
2014 Ford F-250 Ext. Cab Service Truck (A59230)
2014 Ford F-250...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
2017 Thompson 32HPU 55kW Towable Pump (A59228)
2017 Thompson...
