Snow Attachments 3320 john deere snow plow help
   / 3320 john deere snow plow help #1
sparker133
Green bay, Wi
2013 Deere 4320 cab, 180 loader, 485 backhoe, 2021 Deere 1023e, Vermeer trencher, 2022 Deere 26g
I have a 3320 and i just pick up a snow plow. I don't want to hook it up to the fel because of the problems it can cause. I saw a couple of guy mount it the front and used the loader outputs to control it. My questions are what size cylinders do i need, and what is the psi. Where do i get the quick couplers to hook up to the fel couplers. Also, were is a good place to get my part at a good price
   / 3320 john deere snow plow help #2
I put a 7' myers plow on my 3320 loader and it has worked fine but you guys have real snows up there. I mounted mine to my fork lift frame and used the hydraulics for my 4 in 1 to angle the plow.
Dan
   / 3320 john deere snow plow help #3
We need more info, and some pictures. What kind of plow is it? If it's a truck plow like a Meyers, or Fisher, then the stock SA (single acting) cylinders that are meant for it will work just fine. Your JD dealer or a local hydraulic shop can get the QD's for you.
i will get some pictures soon, it is a 8ft western plow blade with single acting cylinders. It came off a truck I it just the blade and a frame. I will fab my own bracket to fit the tractor. Also i am trying to decide to use a chain or use the float control.
   / 3320 john deere snow plow help #5
The SA angle cylinders on that plow will work just fine, but you will still need a DA lift cylinder so you can get some downpressure. A 2x8 or 2x10 3000PSI rated will be fine. The float control on the loader valve will work great-no need for a chain type setup.
do i have to use a SA cylinders or can i use just regular hydraulic cylinder instead. the reason i am asking is because a SA cylinder is $80 and would have to have two. Where i could get on regular cylinder for the same price. Would there be any problems with this.
   / 3320 john deere snow plow help #7
For the angle or the lift?
I am using a regular for the lift. I was talking about the angle on a western blade
   / 3320 john deere snow plow help #9
You can use a double but it may take some modifications. If that is the case it mat be easier to just use 2 SA.
what kind of modifications couldn't i use the same location of the one of the SA cylinders.
43024 (A59228)
43024 (A59228)
2025 GPS Trailers (A56857)
2025 GPS Trailers...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A58375)
2006 TRAIL KING...
2016 Textron T/A 15 Ton Flatbed Equipment Trailer (A59230)
2016 Textron T/A...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
