PTO Generators
   / PTO Generators #1
Porkie
Carthage, Missouri
2000 New Holland TC40D-HST
I know nothing about PTP Generators and need some answers!
Do they have to run at 540 rpm standard PTO speed? If so, that means that on my NH, the engine rpm's would be at 2400!!! I wouldn't think that the Generator would require that kind of speed. Obviously, a person wouldn't want to use this for powering a home for extended periods!
Any one have first hand knowledge?
Thanks, Sam
   / PTO Generators #2
Thanks, Sam
Yes, they have to run at PTO speed if you want to have AC power at 60hz. The frequency of the AC power provided by the generator is directly proportional to the input shaft speed.
   / PTO Generators #3
Thanks, Sam
Why not?
   / PTO Generators #4
I have a 20KW PTO generator and run it at 540 PTO rpm....So what ? and yes for extended periods...Same PTO rpms I run the bush hog for hours and hours...just keep up with your maintenance..these tractors were made to be run and do their job..Where in your owners manual does it tell you not to run your tractor at 540 pto rpm for an extended time ? See my point...?
   / PTO Generators #5
You can run the motor at reduced rpm if you have a pto speed increasing transmission (belts, chains, gears, ropes, mice or pedals). For example I can run mt 540 rpm alternator off my lawnmower which has a 2000 rpm pto. This is done with a 3:1 reducer.
I'd advise you to get a "Kill-a-Watt" frequency and voltage checker, because the tractor tachometers can have error in them. This plugs into the generator or home outlets and displays a digital readout of the current state of your supply.
   / PTO Generators #6
When it rains heavy here, the county at times parks a tractor next the retention pond and pumps the water elsewhere. I know this is not a generator, but if the surrounding area keeps shedding enough water to keep flooding the road, they will leave the tractor there ... running the pump 24 hrs a day.
Seems to me a pump would need at least as much power as a generator.
There have been times during the rainy season or after a hurricane that the tractors will run for more than a week.
When the water threat is gone, they hook the mower back up and keep using the tractor for mowing road sides.
Never seems to hurt the tractors.
   / PTO Generators #7
I believe the design tractors to run their PTO's long and hard.
As far as the power goes running to your house if you live in an area with extended outages you should look into a battery system to provide the power than use your generator to charge the batteries, it will be much cleaner.
   / PTO Generators #8
I thought I read somewhere if you run the PTO for an extended period it should be in HI or LO range (manual transmision) and neutral to keep the oil slinging onto the transmission bearings. Anyone else hear about this? Specifically on a JD 850 is the model I have and read about.
   / PTO Generators #9
You should search on this subject as there are other threads on it.
Personally, I'd not run a PTO generator off my tractor.
Stand alone generators are cheap, I bet in some cases if not most cases they are less than PTO.
Easy to set up, I just role mine out of my garage, start up and plug in my pig tail.
If it was run off my tractor, I'd need to go out to my tractor, start it up, drop off what ever is attached (typically backhoe), then hook up the generator, then move cars so I can park it near the house, then plug in.
I'd much rather put hours on my $400 6500 watt generator than my $20K tractor.
If the generator fails, I buy another, still way ahead of the game.
My stand alone has worked great for me, ran it 4 days straight a couple of years ago with no issues. Neighbor ran his 8 days straight. Would've sucked to put 200 hours on my tractor if I had been him without the stand alone.
Joel
   / PTO Generators #10
Thanks, Sam
Sam,
I've had the same questions.......my Kubota has a 2 speed PTO
540 RPM=2876 engine rpm.........960 rpm=2722 engine rpm
12.7 kW(17 HP)
I've wondered if running the tractor 24/7 @ 2876 rpm would be wasting energy and loud......
Could a PTO Generator of lesser wattage output be run with the PTO in the high speed (960) setting and run the rpm's down to attain 540 rpm's.....without doing the exact math it seems it would run around 1500/1600 or so rpm's.......Seems it would be better on fuel and noise......
I'd also worry about running out of fuel at higher rpm's as the tank on the tractor is small in comparison.
I didn't mean to hijack but your questions seem to be mine also......:confused:
   / PTO Generators #11
Joel
And I look at it nearly the exact opposite.
Having multiple tractors I do NOT want another engine to maintain and stock fuel for.
If one tractor has a problem I can always hook another on it. The hours would be nil in the scheme of things.
Plus we power different locations so it is easier just to hook up the generator and tow it to where we need it.
   / PTO Generators #12
Another good point on run time.
My stand alone will run for about 12-14 hours on a tank.
Anyone know how long a typical tractor will run at 3/4 throttle with on and off load on a tank? I'm betting at least 8 hours?
Joel
   / PTO Generators #13
Joel
What's a typical tractor? lol
I use a 265 MF with a 18 gallon tank @~ 1gal/hour.
   / PTO Generators #14
Joel
There are some good rules of thumb on power generation fuel consumption.
If a diesel powered generator is operating at between 25%-100% of it HP rating then it consumes between 0.07 -0.08 gallon per KWH.
So a 30 HP tractor running a 15KW then the fuel usage would be aprox.
15 x 0.07= 1.05GPH to 15 x 0.08=1.2GPH
These are rulesof thumb and will get into the ball park. There are some exceptions to the rule as always.
   / PTO Generators #15
During the wind storm 2 years ago I used my 7k pto generater (from n tool) behind a yanmar 2000 for 8 hrs a day for 2 days in 2nd pto gear.About 2000 rpm's,a little less than 1 gal an hr. The lites had a suttlele flicker to them but every thing worked. tv computer water heater 1 burner on the stove nothing heavyer.
   / PTO Generators #16
Thanks,
Therefore, my 30 HP tractor, with a 7.5 gallon tank would run for about 6.25 hours on a tank running 15KW. That is a little over double the KW of my stand alone. The 6KW runs my house though. I'd be at about a wash as far as run time if I was running a 6KW three point generator. I guess I'd loose a little through the tractor's gearbox.
I know there are various views on this subject and maybe I'm just a tractor babyier, but kills me to think of my tractor sitting there running for days on end.
Joel
Joel
   / PTO Generators #17
I shut the stove breaker, even a burning does a number on my generator. Runs the well pump, furnace, all lights, TV's computers, etc. Just not the stove top or stove or dryer.
I can't believe winter is almost here.
Joel
   / PTO Generators #18
How does a PTO generator deal with different loads? A stand alone has a governor that will adjust the throttle to keep the RPM at the set point. A PTO generator feeds nothing back to the tractor. Do you set the RPMs a little high with no load or is the drop not enough to worry about?
   / PTO Generators #19
Thanks,
Joel
Joel
I suspect that a tractor may be at the high end of consumption(less fuel effiecient) because of the gearing that isnt used when you have a dedicated diesel directly connected to a generator. Remember the consumption is directly proportional to the load in KW so if you are not using the entire
15KW the it would use less fuel. Clear as mud? :)
   / PTO Generators #20
I have a stand alone generator also, it can not come anywhere close to the PTO generators in terms of kW. I think my stand alone is 6500, most the PTO once sized for my tractor are 15000.
2018 CATERPILLAR 259D SKID STEER (A60429)
2018 CATERPILLAR...
2012 FREIGHTLINER CASCADIA SLEEPER (A59905)
2012 FREIGHTLINER...
2022 Caterpillar 906M Compact Articulated Wheel Loader (A56857)
2022 Caterpillar...
Club Car Utility Cart (A55851)
Club Car Utility...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
Ford 8210 (A60462)
Ford 8210 (A60462)
