Manifold grease fitting
   / Manifold grease fitting #1
birddog10
SW Michigan
Massey 35; gas; 1962
So I've got a new exhaust manifold for my Massey 35 and it has a hole on the upper section, for a grease fitting. I'm assuming it's a grease fitting because my old manifold, which is still on the tractor, has a grease fitting in the same place. At least it appears to be a grease fitting (small nipple like protrusion with the end that looks like a ball point pen). My new manifold didn't come with the fitting so I guess I need to buy a new one or just take the old one out and reinsert it. But my question is: "What the heck does a manifold have a grease fitting for?" What needs greased or lubricated? I've asked a few friends who are somewhat mechanically inclined and they are stumped:confused2: So I'm asking the experts on this site for more information:)
Thanks for any input.
B-dog
   / Manifold grease fitting #3
You got me on that one. :confused3: Can't see a reason for it.
   / Manifold grease fitting #5
Greasing an exhaust manifold would be the start of a very bad day.
   / Manifold grease fitting #6
The hole is probably for an exhaust pyrometer to measure exhaust temp, though I've never seen one mounted on a Massey. I'm guessing the previous owner also replaced the manifold, and was at a loss as to what to plug the hole with. Noticing a grease fitting was the right size, in it went.
Can't say I'd recommend greasing it though.
Sean
   / Manifold grease fitting #7
Sean
An exhaust gas temperature gauge is all I can think of also. A requirement on turbo motors. I don't think the 35's came with a turbo.
   / Manifold grease fitting #9
Perhaps this manifold is common to another engine that does have a turbo?:confused:
Put a grease nipple in it and confuse everyone when you ask them how much grease you should put in!:thumbsup:
   / Manifold grease fitting #10
Put a steel plug in it.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
Kubota M4700 (A60462)
2015 Ford F-250 Crew Cab Pickup Truck (A59230)
2015 Ford F-250...
2011 CATERPILLAR CP56 PADFOOT ROLLER (A60429)
2011 CATERPILLAR...
2019 CATERPILLAR 239D3 SKID STEER (A60429)
2019 CATERPILLAR...
