What would you by instead of KubotaM126?
   / What would you by instead of KubotaM126?
If they won't finance a tiller they won't lease it either I'd bet.
I'd look at a MF 5460 or 5465, you can set them up with the same types of options.
In JD I'd say a 6000 series in the same hp should be able to be setup the same.
In case-new holland, I don't know their current numbering, a the size you're at would be a large TS or small TM in the old numbering.
I was thinking about having my John Deere dealer quote on a JD6140.
   / What would you by instead of KubotaM126? #13
What about leasing as an option? Using 50% as a residual, the financing is based on the remaining 50%, usually with little or no down payment and competetive interest rates:)
Problem is after the lease you have no tractor. :(
I'd rather buy used than lease new,but that's just a personal opinion.
I think I can get a lease with a 10% buyout at the end. I did that on an irrigation engine. Worked out good and maybe I should look at that on this tractor. Thanks.
10222 (A56858)
10222 (A56858)
Mini John Deere Truck (A55853)
Mini John Deere...
9000 (A47477)
9000 (A47477)
2002 International 9200i Truck (A56438)
2002 International...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
CAT Chassis Only (A59076)
CAT Chassis Only...
