texasjohn
Super Member
Find out what the leash laws are in your state and county. Where I live, a dog owner is supposed to keep his dogs under control at all times. This means on a leash or otherwise controlled.
I have verified with my county animal control officers that I have "every right" to protect myself and my property from one or more dogs by any means necessary, including lethal force.
That said, I'd discuss the problem with your neighbor.... calling the police to do this job at this point will simply cause hard feelings. You may end up there, but try to avoid that if possible. The existing barb wire fence is not intended to control dogs, nor should it be improved to do so...at least at any cost to you.
Further, since you have a weapon already, I'd suggest you carry it until you are convinced the canine menace is completely neutralized....the events can occur again and the neighbor might not be available to do a dog recall.
Fundamentally, you need to mentally make your decision NOW.... about how you will handle these dogs on your property in the future. If it were me, I'd pull the pistol which I always carry, on ranch and off, at first sighting and prepare to begin fire at the maximum effective pistol range because it takes almost no time for a dog to close the distance from there to your throat. Such a large dog is lethal... thus, you need to go thru your thought process NOW rather than when next faced with a charging pair of dogs. At that point you do not have time to think, only to act on a prior decision which you are fully prepared to execute.
