Mow with my bx24 or buy a zero turn mower?
   / Mow with my bx24 or buy a zero turn mower? #61
I mow my front and side in 20 minutes (almost 1/2 acre) and that is the outcome..A BX is a better tool since it does more then single use ZTR. Cant install lawn sprinklers, move 30 yards of mulch, a little backhoe to play with! :)
And the mowing is not bad either.
For sure a BX is more versatile, and I love my BX. But if mowing is the only single job a machine needs to do, however, then the ZTR beats the BX hands down.
   / Mow with my bx24 or buy a zero turn mower? #62
I mow about 6 acres with my BX. Would a z-turn be faster, yes. But it doesn't necessarily take me days with the tractor either. I would say for 2 acres, the 60" deck on the BX is more than fine. I think 4K for the deck is a little steep though...
The $4000 was for the deck and bagger setup.
   / Mow with my bx24 or buy a zero turn mower? #64
Sure in price only..Speed it is a toss up.But again it is a single use tool..Why buy? My buddly bought a ZTR and the 2 months later he wants a BH job..I said you should have skipped the $8K ZTR bud..
   / Mow with my bx24 or buy a zero turn mower? #65
I agree, I pauid $1600 for my 60" MMM.
Anyone had any problems with the weight of the BX on the yard? I have R4's and if it is at all wet it really seems to tear up the yard (of course I usually have the loader and shredder on).
   / Mow with my bx24 or buy a zero turn mower? #67
..Speed it is a toss up...
Have to disagree with that (in general), though it depends upon the specific model. In general, for the same $$, it is MHO that the same $$ will gain more speed in a ZTR. There's also the issue of how well a BX is going to cut if you run it at highest speed in high range. Mine will not cut more than a tiny bit at that speed.
it is a single use tool..Why buy?.
Cause someone has a single use for it to do and it does the job both better and faster.
Yea, he made a mistake. He didn't know his needs. Some people do think it through and know their uses before they buy. For me, just like you, the BX is the best choice. But that's no reason to tell other people the BX is the only choice for them. It is important to see things from other people's perspectives too. For some situations, a ZTR really is a much better choice than a BX. Otherwise, there wouldn't be a market for them.
   / Mow with my bx24 or buy a zero turn mower? #68
I've got a Troy Built ZTR that's just about had it. It's a 52" cut and will knock out about 5 acres in a couple hours. I do have the BX 25 with a 60" MMM that I'll be using a lot this season. Is it capable of mowing at top speed like the ZTR? If so, they are about eqaul on mowing speed. It's the quick turns that probably will make the Troy Built a little quicker I'm guessing.
   / Mow with my bx24 or buy a zero turn mower? #69
The BX 2660 has a top speed of 8.1MPH, your BX25 is probably the same. Check to see what your ZTR's top speed is.
Aaron Z
   / Mow with my bx24 or buy a zero turn mower? #70
Aaron Z
From what I've gathered, the Troy Bilt has a maximum forward speed of 6 MPH....also, I goofed, I think it's actually a 50" cut.
I'm guessing mowing time of the BX vs. the TB will probably be a wash. That's good! How fast do you guys with the BX MMM mow? Full speed, half speed, low range, high range????
Non running toro mower (A48082)
Non running toro...
2025 GIYI Skid Steer Plate Grabber (A50322)
2025 GIYI Skid...
2017 Nissan Titan SV (A50323)
2017 Nissan Titan...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
John Deere 2700 5 Bottom Plow (A50514)
John Deere 2700 5...
