Shop tools you wish you had
   / Shop tools you wish you had #61
I wish I had a hoist, it looks like you can pick one up for less than 2k. Then I would have to add on to my shop with a taller ceiling in the new part. I also wish I had some welding stuff, but then I would have to learn to weld. I also wish I had a parts washer, and a bead blast cabinet. I'm pretty lucky, as a rule, I have most of the tools I need, and a pretty decent shop to use them in. Here is a picture of my shop, one thing I would do different is put in a much higher ceiling and one oversized door.
That's a nice shop though, far away from everyone so you can make noise all night :) As far as welders go, pick up a cheap wire fed from Harbor freight to play with. It won't do thast bad and give you an idea of if you'll use it or not. I personally just added a high end tig to my list! Had a big weding job and "borrowed" this one for fabricating and LOVED it. Hobart and a 120 volt. Sweat welds with very little grinding and no fill. To bad you can't use them on a windy day though outside. My cheapy did just fine for the install though, just a little more clean up.
   / Shop tools you wish you had #62
Instead of buying from Harbor Scrap, why not buy a Miller, Lincoln, or Hobart?
Once you have the welder you will realize there is a difference. The question is; Will you be smiling, or wishing you had the money to spend again? Oh, and I have
a H. S. under my work bench. Total use, about 10 minutes. Also I have a Miller 250, that was money well spent.:)
   / Shop tools you wish you had #63
On my short list and have almost pulled the trigger on a number of times had it not been for the fact i have no concrete floor'd shop to put them in
metal lathe
Bridgeport end mill
plasma cutter capable of up to 3/4"
Pro-tools (which i think is now JMR) bender with about 8 different dies
2 post automotive lift
an all in one atv/riding lawnmower/motorcycle lift
A decent oscilloscope to do electronics troubleshooting.
   / Shop tools you wish you had #64
But 89 bucks to see if you'll even use it much vs the 3500 for a nice set up... Can be worth the test. I'll admit though, I liked the Hobart I borrowed alot more than my Lincoln stick and the HF cheapy I have. That said, my cheapy has it's place in my system since if it gets wet or wrecked, not a big deal. I can also lay a pretty decent weld with it... HF while hated, does have it's place.
I'm pretty hard on tools :) That's why if it matters, the tool (as an example) will be snap on, festool and the sort.
   / Shop tools you wish you had #65
Instead of spending $89, I would go play with someone else's welder. Then I would talk to the guys at the local welding supply to get their recommendations. Then I would buy whatever seemed like the best value. I might end up buying from Lowe's, H. D., or TSC.
I was told Snap-on welders were made by Century. Might as well buy Blue, Red, or Gray from the welding supplier for the same money and get dealer support.
I used a guy's Century for a couple of years. He traded it away for a sandblaster, and bought a Snap-on on the payment plan. Twelve years later, the Snap-on has yet to run a bead. Since the S-O was never set up correctly and was only bought for show, I bought my Miller 250 with cash. He might still be paying on the S-O. The Miller was less than $1800 with the purchased bottle.
   / Shop tools you wish you had #66
Snap on only for hand tools. I like the fact they will come to you to replace them when they break. But you spend for that privilege and Craftsman is much cheaper now a days. Too bad the policy for Craftsman now is to repair vs replace.
   / Shop tools you wish you had #67
I need two things;
1) cutting tools that cut straight --> all mine cut crooked!
2) measuring tools that get the right number --> all mine are too long or too short!
:laughing:
   / Shop tools you wish you had #68
How high would you have made the inside ceiling for a lift and what size OHD..??......
Hind sight is 20-20, but I'm still in the planning stage for my garage (hopefully will do the dirt/concrete work this summer.....
   / Shop tools you wish you had #69
:laughing:
You can always use the eyeball micrometer or a rubber band to measure with, they are always right....
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
2020 Ford F-250 Pickup Truck (A51692)
2020 Ford F-250...
(INOP) KUBOTA L2550 TRACTOR (A51247)
(INOP) KUBOTA...
CHALLENGER MT525B TRACTOR (A51247)
CHALLENGER MT525B...
NORTHERN 3P-100 AG MIST SPRAYER (A51247)
NORTHERN 3P-100 AG...
2009 Wells Cargo 5th Wheel Office Trailer (A53117)
2009 Wells Cargo...
