Blown JD 955 front axle. Anyone source a used unit?
   / Blown JD 955 front axle. Anyone source a used unit? #1
The Haymaker
Benton, Maine
2008 T2220
As the subject says, anyone have some ideas? RH side. Looks like a ball popped out of the bottom cup bearing and somehow made its way to the gear, which forced the bearing assembly outward.
Thanks in advance,
E
   / Blown JD 955 front axle. Anyone source a used unit? #2
Ouch! That is not a pretty site. More than just the cast housing broken?
No chance to replace bearings and seals, and welding cast back together?
Maybe a used parts yard if only alternative.
Used is what I am hoping someone will come up with. There is a bearing in the bottom of it so even though the housing can probably be welded, getting the bearing snug and lined up again is another issue.
   / Blown JD 955 front axle. Anyone source a used unit? #4
Ouch is right...that brought a tear to my eye:eek: That must have made one he!! of a bang when it went.
"Like a bomb going off" is what my Dad said. There's a pretty good splatter mark in the yard too. Not good, he's going to have a hard time coming up with the cash for this one.
Update: Some patience and a little 7018 rod.
Will it work? Time will tell. Even at 38, my Dad still amazes me.
   / Blown JD 955 front axle. Anyone source a used unit? #9
Sorry to see that! I just got through rebuilding my front-end on my 790 which looks real close to yours. It cost me just in part $1360 and that was not all the gears. Maybe a 790 or 990 will work. Know it sucks being planting time and such. One more thing. Have u looked at the shaft in that housing and area to see what caused that to happen? Good luck my friend!
   / Blown JD 955 front axle. Anyone source a used unit? #10
Looking at the very 1st pic. it looks like the bottom drive gear is chunked up some. Maybe not I hope because, that gear alone is $85.
2021 SANY SY265C LC LONG REACH EXCAVATOR (A59823)
2021 SANY SY265C...
American G-Model Pump Jack (A56438)
American G-Model...
set of 4 tractor trailer tires Roadforce (A56438)
set of 4 tractor...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A56438)
PENDING SELLER...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
(2) UNUSED 460/85R30 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
