Modn
I said FULL PTO rpms, not full ENGINE rpms. In my tractor, they are one and the same, as far as I can tell. I fail to see the "vast danger" in doing so, as that is how it is designed to run. I control log speed with the clutch rope. Slip the clutch a little to slow down if needed. Mine is also on the lower end of hp for a winch, so I need everything I can get. With a 50 hp L5030, he is in a better position power wise, so he may not need full PTO speed for everything.
While I noted that you need to give it a good yank to get started, that is not totally how I run things - I should have been more clear. I start slow in general, but if you have a big log, you have a bunch of inertia to overcome so full power can be needed at those times, so a hard tug is needed to get that. That comes with experience.
Modn - It does seem like your clutch may need adjusting too.
It does need adjusting just from talking to the dealer. If I pull hard enough...real hard, I can hit the lever on the housing.......it's not supposed to do that. I'm confident this will be the answer. Again thanks everyone for the insight.:thumbsup:
