Things to inspect on manure spredders
   / Things to inspect on manure spredders #11
if you're going to go out and replace stuff every time you see a problem especially a manure spreader then you're going to run out of money pretty quick. Take the chain out of the machine and repair the crossers, then make sure that they are all spaced exactly even. The guy told you that it jumped which means it was loose, this is what ultimately caused the slats to break off as they rolled around the ends when one side got ahead of the other. I'm more than positive judging by the pictures that there is a lot of life left in that machine.
Flights is what Been called them I figured they were the bars. The chain and bar things are rusted really bad, most bars are broken. I found the bolts which is how to remove the current chain. All of the equipment on the farm was abused by the last field person. I knew him (the reason the chain is hitched is he was liquor drunk 90% of the time) and he left it that way. I found a finish mower in the weeds missing a wheel (I am hoping that is the next piece I fix up). I am not a life farmer, I didn't know that machine shops (places to fix stuff) existed. Do I just take in the broken bars? I am not trying to throw money away, I just don't know what else to do but replace.
I can clean, grease, oil and that is the extent of my knowledge. The barn manager (horse farm) doesn't give a rats a**, she said let the fields go to weeds. I started out just BHing my horse's two rotational pastures. Then other boarders asked me to do their horses fields. I am unpaid labor, the owner said I can use anything I want on the farm. We also have a manure pile the size of 6 tractor trailers. I sent off soil and compost samples and am working with the Ag Extension to put into action what I learned in my Ag Degree, but they at least at my school don't teach tractors 101 or anything like that. As my screen name implies, I am learning to farm. My joy is that the farm looks better and the horses are not on weeds.
Sorry for the rant-
How do I decide what a good price to fix all the bars is? I mean if all have to be repaired is it better to replace in that instance?
How long should it take?
Will they wield them?
How much rust is to much rust?
How do you clean out a manure spreader when done, sweep? (to prevent rusting)
Hey grst I looked on Shoups don't see just the flights, bars, crossers? I broke down and they are sending me paper catalog, maybe that will make it easier to find replacements if they can't be fixed.
And for the last question of my last post, I know there is going to be rust. I am looking to slow the process.
   / Things to inspect on manure spredders #14
I think learning to weld should be pretty high on your priority list. You can probably find a used, but darn good welder for $200-300 and save that same amount of money after the first repair or two. Since you have a working farm things will likely keep breaking on the semi-regular bases.
   / Things to inspect on manure spredders #15
I'm grew up farming and don't know the technical terms for most things. We called the whole moving chain works the apron. The flights I believe are the crossbars plus the special attaching link. I have a Fleet Farm store near me that sells various size chain links in lengths or singles. They also sell the special links (there is a difference between left and right). I have ground the rivets off and replaced with bolt/nut instead of rivets.
The links do wear. You can see what part of the link slides on the deck. That metal will get thin. Your wallet might dictate how far you let them go but I wouldn't go beyond half thickness or they will start breaking. How heavy the loads are also affect them.
One more thing to check are the wheel hubs. They varied from a grease zerk to automotive style bearing that needs to be disassembled and repacked.
   / Things to inspect on manure spredders #16
i purchased some 6-10 foot lengths of several styles of chains and some left & right links about 3-4 years ago. i simply replace them as needed. I also thoroughly hose off and store the spreader under cover when not in use. This prevents alot of deterioration. Manure can eat away metal pretty fast.
I wont replace the entire chain, cause im too cheap hehe. Alos, i too replace an occasional rivit with a nut and bolt. this works just as good.
I just fix it as i need to. One thing i did do is drill out holes and install cotter pins behind alot of the large nuts holding the gears and shafts on. i noticed that there always backing off and i even lost one (found it with metal detector as the bearing fell off also).
   / Things to inspect on manure spredders #17
I notice that Shoup's calls the flights, bars, crossers by the name of slats. These slats may be just steel angle iron that can be bolted to the right and left t-bar chain links. If so, repair will be much easier than trying to weld them up. Deere calls the crossers 'flights' and the assembly that I've always known as the apron, they call the conveyor. So names are all around the place. :) But they all are the movers. ;)
For rust, many will use a pressure washer to clean the spreader after manure use, and then if storing it for a period of time will spray it down with used motor oil. That will help the rust and also help preserve any wood in the floor boards.
   / Things to inspect on manure spredders #18
your right ...mine look like simple angle iron. there rivited to the left/right chain links. looks like soemthing one can make themselves with very little effort.
Easygo, well like I said the guy that tended to the equipment last treated it like trash. Here is what I found under a pile of junk (or what I perceive to be junk)
   / Things to inspect on manure spredders #20
heres my little spreaders home :)
*Selling at Royal Auction Tampa, FL Location* Year: 2017 Make: Dodge Model: Charger Vehicle Type: (A59231)
*Selling at Royal...
2018 INTERNATIONAL RH613 TANDEM AXLE DAY CAB (A59575)
2018 INTERNATIONAL...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
2018 Dodge Ram 3500 (A53317)
2018 Dodge Ram...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
*Selling at Royal Auction Tampa, FL Location* (A59228)
