Pics of my new Kubota L3940
   / Pics of my new Kubota L3940
The plywood roof I made:
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
The roof is 1/2" pressure treated plywood, the full 48" wide & 67" long (need to measure it).
Under the roof are two 2x4's with notches for the ROPS. Also, crossways under the roof is a 2x8.
The 2 diagonal supports are 1.5"x1.5" steel square tube members.
The roof & the 2 diagonal supports are connected to the ROPS using square U-bolts.
I used a plate from the kitchen to draw the rounded corners, then cut them with a jig saw. Then routed the edge of the plywood, top & bottom with a little corner-round (quarter-round?) bit.
I painted the entire thing with black fence paint from Tractor Supply. That stuff is great: Covers great & doesn't require perfect surface prep.
I believe the cash outlay for this roof was about $100. About $25 for the plywood. Maybe $5 each for the 4 U-bolts. I already had the 5-gallon container of paint. The steel was something like $14/ each. A couple 2x4's & a 2x8.
Feel free to ask questions if you have any.
Edit: Forgot to menton, with the plywood sitting right on top of the ROPS like this, with the supporting 2x4's below the ROPS as you see, this only increases the tractor's overall height by about 1 inch (1/2" for the plywood plus ~1/2" for the threaded ends of the square U-bolts coming up thru the plywood).
Edit 2: I used the 2x4's & 2x8 like this because I want to be able to stand on the roof & cut limbs very high with the pole saw. I haven't actually tried it yet :eek: I will, very carefully(!), just haven't needed to yet.
Nicely done,
Dont mind if I copy it, it is a winner.
Sure, no problem - As long as when you talk about it, you call it "The Beppington" ... OK, or "The Bepp" for short :laughing:
   / Pics of my new Kubota L3940 #74
Nice project...may also copy after I get through several other projects, thanks for the pics and detailed list of items.
Kubota loader model LA724 lift specs on a Kubota Grand L3940:
Maximum Lift Height (Pivot pin): 102.2"
Clearance with Attachment Dump: 78.5"
Reach @ Maximum Height: 22.1"
Maximum Dump Angle: 45 deg.
Reach with Attachment on Ground: 69.4"
Maximum Rollback Angle: 41 deg.
Digging Depth (When Bucket is level): 4.8"
Overall Height in Carry Position: 54.3"
Square Bucket Width / Struck Capacity: 72" / 10.9 cu. ft.
Lift Capacity (Pivot pin): 1,865 lbs.
Lift Capacity (500mm (19.69") forward): 1,415 lbs.
Breakout Force (500mm (19.69") forward): 2,623 lbs.
Raising Time to Full Height without Load: 3.2 seconds
Lowering Time without Load (powerdown): 2.0 seconds
Attachment Rollback Time: 1.9 seconds
Attachment Dumping Time: 1.3 seconds
Rated Flow: 9.8 GPM (gallons per minute)
Relief Valve PSI: 2,630 psi
3PH lift capacity: 2,760 lbs 24" behind the lift point
Some pics I took of my parents' mini horses:
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
Some pics I took of the Silver River in Ocala, FL & some inhabitants:
attachment.php
attachment.php
attachment.php
   / Pics of my new Kubota L3940 #78
Darn, spent many days/hours in Alachua, FL and around Ocala for work back in the 90's and never saw any monkeys! Saw a lot of the little lizzards, it was all the rage for the ladies to dangle them from their ear lobes as jewelry... not much to do in Alachua if you don't got to Gainesville. :confused2:
The rhesus monkeys are only along the Silver River & aren't native. Recall Silver Springs park with its glass bottom boat rides? The Silver River flows out of there. Here's why they're there:
In the 1930s, "Colonel Tooey, a concessionaire who operated the Jungle Cruise boat ride, established the first troop of wild rhesus monkeys on an island in the Silver River. Tooey established the colony to attract visitors to his ride. He did not realize the rhesus monkeys were excellent swimmers. They quickly escaped, forming wild troops along the river."
1932-42 Six of the original Tarzan movies, starring Johnny Weissmuller, were filmed on location at Silver Springs.
1958-1961 More than 100 episodes of "Sea Hunt," starring Lloyd Bridges, were filmed at Silver Springs.
Today I discovered this nice little slot in my L3940's LA724 loader (slot on both sides) that holds my machete (one on each side if you want) in a secure, easy access location, no mods necessary, just drop it in / lift it out. Haven't found any downsides to it so far, of course it's only been a day.
John Deere 2440 Tractor (A52384)
John Deere 2440...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2010 Nissan Sentra Sedan (A51694)
2010 Nissan Sentra...
12 in Large Excavator Bucket (A52377)
12 in Large...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
2023 G Bar K Skirted Hauler Bed (A53472)
2023 G Bar K...
