Look what I found in the woods!
   / Look what I found in the woods! #1
Painer
Hey all, I've never really posted here but use the forums all the time for help.
I've always wanted to restore an old Ford. So I have a neighbor that turns out has one in the woods behind his house. I'll post the pictures I took today of it and get y'alls input.
Rear side view
The gas tank went bad at one time so they fashioned up this rig to provide gas
Underside of the home-made gas tank
SAE number
Front view
Why I want it :)
Generator
Again
Seating area - didn't lift the bucket for wasps lol
Production number
View from the dirt road it's off of on his property
I'm looking at a complete resto project that I can take easy and learn about old iron. The owner is a bit proud of it and is currently looking for 800$. I offered 400$ and we're going back and forth right now.
What I know it needs -
Engine re-done - owner says "it runs on 3 cylinders"
Not sure of hydraulics but owner claims they work great
Definitely needs new back tires - front are ok
Paint
Wiring
Once again, I'm planning on complete resto so I'm not really wanting to offer much more than scrap value - am I being too cheap? Is the 800 worth it? It's been sitting in the woods for years and they have no intention of doing anything with it so I am hoping they will see a bird in the hand is worth two in the bush.
Thanks so much for looking and your advice gentlemen
Christian
Remlap, Alabama
   / Look what I found in the woods! #2
Nice find
That looks like an alternator, and that means that some one did a 12 v conversion.
   / Look what I found in the woods! #3
they normally bring at salvage auction i go to from 750 to 1250 if totally complete and the motor not stuck and thats for parts tractors i have seen them go as cheap as 500
Thanks guys, and yes I meant alternator sorry I sometimes interchange those two. I may go up a bit on my price but what I have figured so far is that the owners definition of "works good" and mine are different.
   / Look what I found in the woods! #5
I'm restoring a 1951 Minneapolis Moline BF tractor, about the same size and vintage as your Ford. Paid $1300 for a non-running tractor because I really wanted that baby for my collection (I restore old tractors with bull gear rear axles). It's a money pit-
No compression (4-cyl Hercules engine)--$800 parts, $800 labor (new pistons, rings, valves, valve seats, machine the cylinders 0.020" over, machine the crankshaft, machine the head, machine the flywheel)
Rebuild water pump ($120)
New clutch pack ($150)
New manifolds ($200)
Carb rebuild ($50 parts
I figure I'll have $4500 in that tractor before it's parade ready.
You'll probably have the same expenses for that Ford plus a good deal of sheet metal work (it looks pretty rusty from your photos). Fortunately, the sheet metal on my BF is in great shape.
Good luck
   / Look what I found in the woods! #6
I think 800 is a little high. I have a Ford Jubilee that I've worked on some.
If it runs I may offer 650.00 if I really wanted it. It looks like it will need some major redoing. It all adds up quick.
Good luck!
   / Look what I found in the woods! #7
by the way.. those raised casting numbers you referred to as a sae # and production code were neither.
SN were hand stamped..
for a naa.. it would read naa and then the sn.. no production code on that model.
a non runner rusted away int he woods is worth about 50-150$ at most, here in florida.
soundguy
soundguy
   / Look what I found in the woods! #8
soundguy
soundguy
i wish i was in florida i would like to have some of them tractors for around 100 bucks because i see 650 dollars worth of rims and tires 150 dollars worth of lift arms a 400 dollar head and a 250 dollar steering box not to metion all the other little parts on that tractor one like that around me u can sell to get for 400 but no likely everytime i get one of them in my shop to salvage i have the head back tires and steering box sold before i can get them took off
   / Look what I found in the woods! #9
No kidding. Here in Wisconsin you'd think they were stuffed with diamonds, rubies, pearls and emeralds before being left to rot in the hedge rows...:confused2:
People are WAY proud of their junk around here.
   / Look what I found in the woods! #10
thats must be it
i've seen them bring as much not running bring as much as running ones its hard to find a nonrunner under 500
1985 AM General M35A2C 2.5 Ton 6x6 Fire Rescue Truck (A50323)
1985 AM General...
2020 Freightliner M2 106 S/A Dump Truck (A50323)
2020 Freightliner...
2017 Big Tex 10ET T/A Flatbed Equipment Trailer (A50323)
2017 Big Tex 10ET...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A52748)
Kubota 24in Quick...
1999 Toyota Camry XLE Sedan (A50324)
1999 Toyota Camry...
2014 Ram 1500 Crew Cab Pickup Truck (A50323)
2014 Ram 1500 Crew...
