Any compacts between 18 & 28 HP with a live PTO????
   / Any compacts between 18 & 28 HP with a live PTO???? #41
Did just find a Branson 2800 120 miles from here new for $12,500 I see it's a turbo'd Cummins but can't find anything on the pto. Anyone own one??
I thought that you wanted a loader? That sure sounds like quite a good price if it has a loader with it. :drool:
I would guess that it has an independent PTO.
Listing is as follows:
Branson 2800 4x4 Tractor w/ BL00 Loader
28hp 3-cylinder Cummins A-Series Diesel Engine
Differential Lock
6Fx2R Manual Transmission
Rear and Mid PTO
Category 1 3-Point
48" Front Loader Bucket
900lb Loader Lift Capacity
4-year factory warranty
$12,495
   / Any compacts between 18 & 28 HP with a live PTO???? #43
If you look at Bransons website you will see the specs for the 2800 indicate a 6 spline pto, when you look at the next model up the specs indicate "independent pto". I suspect if the 2800 had an independent pto they would be more specific.
They also have a short paragraph in their "About Branson tractors" you might wan't to peruse to see if it helps you.
   / Any compacts between 18 & 28 HP with a live PTO???? #44
Differential Lock
Rear and Mid PTO
Category 1 3-Point
$12,495
At 1800lbs and the overall size and capacity of the machine, with only a 48" wide bucket and a 900lb lift capacity, this is a small tractor and not at all what I was thinking that you were looking for.
With multiple properties, I figured that you were looking for something a bit bigger than that. But if that looks like it will work for you, then I guess that you're all set. ;)
Bigger would be nice but i have to fit through 48" gates on many properties. This is the battle.............
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
City of Buckhannon - 1990 International 2574 Truck (A52384)
City of Buckhannon...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
JOHN DEERE 1705/6700 LOT IDENTIFIER 20 (A53084)
JOHN DEERE...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
