Any compacts between 18 & 28 HP with a live PTO????
   / Any compacts between 18 & 28 HP with a live PTO???? #41
Did just find a Branson 2800 120 miles from here new for $12,500 I see it's a turbo'd Cummins but can't find anything on the pto. Anyone own one??
I thought that you wanted a loader? That sure sounds like quite a good price if it has a loader with it. :drool:
I would guess that it has an independent PTO.
Listing is as follows:
Branson 2800 4x4 Tractor w/ BL00 Loader
28hp 3-cylinder Cummins A-Series Diesel Engine
Differential Lock
6Fx2R Manual Transmission
Rear and Mid PTO
Category 1 3-Point
48" Front Loader Bucket
900lb Loader Lift Capacity
4-year factory warranty
$12,495
   / Any compacts between 18 & 28 HP with a live PTO???? #43
If you look at Bransons website you will see the specs for the 2800 indicate a 6 spline pto, when you look at the next model up the specs indicate "independent pto". I suspect if the 2800 had an independent pto they would be more specific.
They also have a short paragraph in their "About Branson tractors" you might wan't to peruse to see if it helps you.
   / Any compacts between 18 & 28 HP with a live PTO???? #44
Differential Lock
Rear and Mid PTO
Category 1 3-Point
$12,495
At 1800lbs and the overall size and capacity of the machine, with only a 48" wide bucket and a 900lb lift capacity, this is a small tractor and not at all what I was thinking that you were looking for.
With multiple properties, I figured that you were looking for something a bit bigger than that. But if that looks like it will work for you, then I guess that you're all set. ;)
Bigger would be nice but i have to fit through 48" gates on many properties. This is the battle.............
550 Tubes Grease Cartridges (A53117)
550 Tubes Grease...
2011 Crown Victoria Sedan (A51694)
2011 Crown...
2005 John Deere L118 Automatic 42in Riding Mower (A51694)
2005 John Deere...
THRESHOLD 30" SQUARE OUTDOOR GAS FIRE TABLE (A51248)
THRESHOLD 30"...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
Blue Concrete Test Shed (A52377)
Blue Concrete Test...
