Need some quick advice, IMatch Hitch Deal
   / Need some quick advice, IMatch Hitch Deal #21
Here it is! :thumbsup:
The Green really clashes with my Orange! :laughing::D
Fits very well and looks like it's gonna work with all my implements... except the trailer mover. :licking:
The trailer mover is too wide at the bottom.... really strange. Will require major surgery to make it work... I may just sell it. I really like it though. :(
So the next step is to add mods to the QH like chain boxes and stuff... also a 2" receiver! :thumbsup: Then it will go to paint... Kubota gray!
I've seen some nice mods on this site. Time to start collecting some pics! :cool:
You will be amazed at what a difference having a little Deere stuff added will help that poor Kubota.:D
LOL! :laughing:
Yeah the Deere stuff will just transform my life! LOL! Maybe that hot model will show up that's always using the IMatch hitch in the Deere brochures! :dance1:
   / Need some quick advice, IMatch Hitch Deal #23
Yes I agree... what's the point of quick hitches if I have to move the top hook! :confused2:
So... if my stuff doesn't line up I will have to modify it. I just hope at least something lines up without cutting! :laughing:
Its the, dial in factor, If your using a mower, bale spear, log splitter,etc a little slop dont mean much, but when your grading, or using tillage equipment alittle slop in the pin to hook really shows up, especially finish grading, with the adjustable hitch you can FAVOR, the more important tool and run the mower as is, or re adjust, your choice, I like the flexability,:thumbsup: Eric
   / Need some quick advice, IMatch Hitch Deal #24
Papa, did they not give you the proper pins for the lower links? They should have a square head on them...
Nah they lost them. :mad: That was another reason for the reduced price. I may order the proper pins... not sure yet. The pins I have in it are temporary.
I may cut the pins down that I have on it now and just use them. They actually fit quite well.
Do you understand why they use those square heads? Is that to prevent the pins from turning? Not sure what the big deal it if the pin turns. :confused2:
What do you think?
   / Need some quick advice, IMatch Hitch Deal #26
While I agree with the implements in operation that don't seem to need the precise fit as you discribe I would also point out that having the proper fit using the proper top link bushings to fit the hook has its own importance. On some equipment I use the bushings and on others I have welded in Cat 3 pins (same size as the top hook) but in all cases setting these to properly fit means that all three points carry the weight. By this I mean that if you have play in the top link hook then the lower pins are carrying all of the weight, Using the correct size pins and bushings reduces deformation of the pins and sockets.
   / Need some quick advice, IMatch Hitch Deal #27
I bought one like this:
3 POINT DRAWBAR HITCH For JOHN DEERE iMATCH Quick Hitch | eBay
off eBay.
The one I bought was from the same seller, but cost about $85. I had to add the bushing kit though. This is also something that could easily be fabricated at home if you have the required tools (welder, for example).
FYI, the tow balls are 1.875 and 2.000 inches. Those, and the clevis are included.
   / Need some quick advice, IMatch Hitch Deal #28
What do you think?
Any pins will do...the square headed ones won't turn-but its no big deal if they do anyway. They also offer a lower profile so as not to stick out and get caught on anything. Go with what works...
   / Need some quick advice, IMatch Hitch Deal #29
I paid $240 from my deere dealer two years back for my Imatch. I also have the woods quick hitch. The deere is a better made unit. I paid$300 for the woods unit. Now it just sits.
   / Need some quick advice, IMatch Hitch Deal #30
What burns me about the TSC hitch is it's EXACTLY the same hitch as the one HF sells for about $100.00....
And the welds on their implements are horrid. A neighbor has bought several from them and most have broken welds with only moderate use. The warranty is also a joke. Basically, once you've used the implement any failure is "abuse".
I'd buy a Imatch for my tractor but the local Deere dealers are too proud of them. Both quoted me 350.00 + tax. $250 I'd pay, but $350 is crazy in my opinion.
UNUSED DIGGIT 20'X30' METAL GARAGE CARPORT SHED (A54757)
UNUSED DIGGIT...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
UNUSED LANDHONOR PF-11-3500G PALLET FORKS (A54757)
UNUSED LANDHONOR...
2010 Toyota Prius Hybrid Hatchback (A53424)
2010 Toyota Prius...
201706 (A54756)
201706 (A54756)
